[GRASS-user] t.register does not register anything in a STVDS
Markus Neteler
neteler at osgeo.org
Fri Feb 24 03:11:52 PST 2017
> Am 24.02.2017 02:48 schrieb "Laurent C." <lrntct at gmail.com>:
>> Hello,
>> I created an empty STVDS that looks fine:
>> t.register seems to works fine:
>> t.register --overwrite --verbose type=vector
>> file=/home/laurent/Datos_geo/kolkata/one_rainfall_event_of_2015/wl_register_list.txt
>> Gathering map information...
>> Registering maps in the temporal database...
>> But no map is added to the STVDS.
On Fri, Feb 24, 2017 at 4:27 AM, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> You need to specify the name of the stvds in t.register.
At time it is optional:
https://grass.osgeo.org/grass72/manuals/t.register.html
There will be a reason for that but probably a warning should be
printed to avoid this issue? (I also ran into this recently).
Markus
