[GRASS-user] subsetting vector db based on selected rows
Ken Mankoff
mankoff at gmail.com
Tue Feb 28 12:25:30 PST 2017
Hi GRASS list,
I'm trying to work with a database and have what I assume is a fairly simple question. I usually work with rasters and am not sure how to update or subset a vector. Specifically, I have the following vector product:
v.info BTMP # output below is trimmed
| Timestamp (first layer): none |
| Map format: native |
| Type of map: vector (level: 2) |
| Number of points: 0 Number of centroids: 3378 |
| Number of lines: 0 Number of boundaries: 9859 |
| Number of areas: 3946 Number of islands: 433 |
| Map is 3D: No |
| Number of dblinks: 1 |
With contents like:
db.select table=BTMP | head
cat|area|termini_id
1|5000479.797168|2
2|27502638.884425|1
3|29502830.803293|2
4|14001343.432071|3
5|3000287.878301|4
6|45004318.174513|4
7|4500431.817451|5
8|1500143.93915|5
9|7000671.716036|6
And I'd like to subset this. I'd like the largest area for each group of "termini_id". I can select the subset I want with the following:
db.select sql="select cat,max(area),termini_id from BTMP GROUP BY termini_id" | head
cat|max(area)|termini_id
2|27502638.884425|1
3|29502830.803293|2
4|14001343.432071|3
6|45004318.174513|4
7|4500431.817451|5
9|7000671.716036|6
11|10751031.563912|7
12|4750455.80731|8
15|80007676.75469|9
But that just prints it to the terminal (our I can output to a file). I'd like to either have a new column with 0's for the non-selected and 1s for the selected rows. I can then display the selected rows using d.vect and the WHERE keyword. Or alternatively a new vector which is a subset of this one, based on the selected rows. How do I do this? I tried to generate the new column:
v.db.addcolumn map=BTMP column="max_basin INT"
db.execute sql="update BTMP set max_basin=1 where max(area) GROUP BY termini_id"
But get errors I'm not sure how to interpret:
DBMI-SQLite driver error:
Error in sqlite3_prepare():
near "GROUP": syntax error
Thanks for any hints to this specific problem or a general tutorial on working with vectors and DBs.
Thanks,
-k.
