[GRASS-user] Color equalization after patching/mosaicking the satellite data from multiple scenes
    Sajid Pareeth
    spareeth at gmail.com
    Sun Jan  1 09:12:48 PST 2017
Hi Nikos,
Thank you for the reply.
some normalisation, before patching, is what "needs" to be done, I think.
> Relative
> normalisation here (either for images of different dates over the same
> area, or neighbouring images of the same date).
Yes I also agree with that, I tried doing histogram matching before running
r.patch, though I am not sure if it is right way. Any idea on how the
change in values due to matching will affect further processing?
> I never finished implementing some very simple process as described in
> user manual(s) for QuickBird2 imagery, if I remember well.
> I have a draft module which I named i.radio.balance. In short:  the
> major difference between two scenes of the same area is the solar
> geometry.  This difference can be minimized by correcting imagery for
> Earth-sun distance and solar zenith angle.
> I can send you off-list, if you want, the on-going script (incomplete, yet
> well
> documented I believe it to be).
> I would be happy to test your code and let you know the results. Let me
know.
Regards
Sajid
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170101/1fd1fd03/attachment.html>
