[GRASS-user] [d.*] command not executing from standalone script
    Ang Sherpa
    angsherpa232 at gmail.com
    Wed Jan  4 02:59:43 PST 2017
Hi Martin,
My script work from "Launch Script" command within Grass Gis environment.
However, as a standalone script it just executes nothing not even error.
So, sleep.time(2) is also not working as expected. Am I missing something?
I have attached the script that I used herewith this mail.
Will be looking forward to hearing from you.
*Regards,*
*Ang Dawa Sherpa*
*GIS technician - Irrigation Master Plan*
*WRPPF - DOI, Nepal Government*
*Lalitpur*
*contact: 984 007 3861*
On Tue, Jan 3, 2017 at 5:18 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2017-01-03 12:13 GMT+01:00 Ang Sherpa <angsherpa232 at gmail.com>:
> [once more, please keep discussion on ML]
> > I tried still no luck. I am in windows 10. I tried whole day so almost
> out
> > of option. Your help will be grateful.
> I tested script on Windows too, it worked, I just needed to increase
> sleep to 2secs. This is hidden bug when using graphical monitors in
> scripts. It should be solved. You should get at least some error. Eg.
> unknown monitor size. Can you reproduce this issue with north carolina
> dataset? If so, please sent us the sample.
> 1) does your script work from running GRASS (launch script from the GUI)
> [1]
> 2) does your script work with file-based display drivers (d.mon
> start=cairo output=/path/to/image.png; d.vect ...; d.mon stop=cairo)
> Ma
> [1] https://trac.osgeo.org/grass/browser/grass/trunk/gui/icons/
> grass/script-load.png
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170104/983d03e9/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170104/983d03e9/attachment.obj>
