[GRASS-user] r.out.bin fails consistently on Windows 10
    Dr Jonathan Ball
    jonathan.ball at mappagnosis.com
    Tue Jan 10 03:14:51 PST 2017
Hi List,
I am trying to use r.out.bin.  I initially tried it from within QGIS and
have moved to using a standalone version of GRASS 7.2 on Windows 10 (64
bit).  I have tested with a variety of rasters and I consistently get
the same error message:  "Unable to create file <output_filename>"
whether I use default settings or tweak the optional parameters.
Since r.out.bin is apparently based on r.out.ascii, I experimented with
that utility and it works well for me with no errors.  I can do a
'round-trip' (export to ascii and then re-import from the output file).
So, the problem seems to be specific to r.out.bin.
Before I log a bug report, can anybody confirm whether this utility
actually works in Windows or offer any pointers as to what I might be
doing wrong?
Many thanks
Jon
