[GRASS-user] r.out.bin fails consistently on Windows 10
Anna Petrášová
kratochanna at gmail.com
Tue Jan 10 06:31:35 PST 2017
On Tue, Jan 10, 2017 at 6:14 AM, Dr Jonathan Ball
<jonathan.ball at mappagnosis.com> wrote:
> Hi List,
> I am trying to use r.out.bin. I initially tried it from within QGIS and
> have moved to using a standalone version of GRASS 7.2 on Windows 10 (64
> bit). I have tested with a variety of rasters and I consistently get the
> same error message: "Unable to create file <output_filename>" whether I use
> default settings or tweak the optional parameters.
I tested 7.2 on Windows and it seems to work ok with default settings.
Have you tried to export it to different place? Perhaps problem with
space on device, just guessing...
Anna
> Since r.out.bin is apparently based on r.out.ascii, I experimented with that
> utility and it works well for me with no errors. I can do a 'round-trip'
> (export to ascii and then re-import from the output file). So, the problem
> seems to be specific to r.out.bin.
> Before I log a bug report, can anybody confirm whether this utility actually
> works in Windows or offer any pointers as to what I might be doing wrong?
> Many thanks
> Jon
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
