[GRASS-user] r.out.bin fails consistently on Windows 10
Dr Jonathan Ball
jonathan.ball at mappagnosis.com
Tue Jan 10 06:54:26 PST 2017
Thanks. That seemed to work! It was not a space issue though, because
there is plenty of space free (over 100GB and my file is not THAT
big!). I can only imagine it is some sort of permissions thing but it
is not obvious what/why. It still fails when run from QGIS though (an
empty file is created here with no error).
On 10/01/2017 14:31, Anna Petrášová wrote:
> Hi,
> On Tue, Jan 10, 2017 at 6:14 AM, Dr Jonathan Ball
> <jonathan.ball at mappagnosis.com> wrote:
>> Hi List,
>> I am trying to use r.out.bin. I initially tried it from within QGIS and
>> have moved to using a standalone version of GRASS 7.2 on Windows 10 (64
>> bit). I have tested with a variety of rasters and I consistently get the
>> same error message: "Unable to create file <output_filename>" whether I use
>> default settings or tweak the optional parameters.
> I tested 7.2 on Windows and it seems to work ok with default settings.
> Have you tried to export it to different place? Perhaps problem with
> space on device, just guessing...
> Anna
>> Since r.out.bin is apparently based on r.out.ascii, I experimented with that
>> utility and it works well for me with no errors. I can do a 'round-trip'
>> (export to ascii and then re-import from the output file). So, the problem
>> seems to be specific to r.out.bin.
>> Before I log a bug report, can anybody confirm whether this utility actually
>> works in Windows or offer any pointers as to what I might be doing wrong?
>> Many thanks
>> Jon
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
*Dr Jonathan Ball*
Director
MappaGnosis Ltd.
/GIS analysis, 3D Modelling & Mapping/
http://www.mappagnosis.com
MappaGnosis Ltd is a member of the Federation of Small Businesses
(http://www.fsb.org.uk).
MappaGnosis Ltd is a private company limited by shares and registered in
Scotland (Company Number: 384525).
When commissioning goods and/or services from MappaGnosis Ltd, please
read the Terms & Conditions
(http://mappagnosis.com/index.php?p=1_13_Terms-Conditions). A direction
to proceed with a job shall be deemed as acceptance of these conditions.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170110/5c2eafc7/attachment.html>
