[GRASS-user] g.gui.mwprecip addon
Matej Krejci
matejkrejci at gmail.com
Tue Jan 17 13:03:37 PST 2017
Hi Micha,
development of g.gui.metada and mw.precip has been stopped. The module is
suited for Postgres database. It basically means you need to know database
structure. Unfortunately, I don't have rights to provide you training data.
I have attached the sample of SQL dump which helps you to create the
database. By modifying COPY statements you can easily add your data.
The computation of average precipitation along link is based on ITU-R
P.838-3(attached). Basically, you specify a dry period for attenuation
baseline computation and the wanted time interval you are interested in.
The main purpose of this module was to preprocess data. It should compute
precipitation and for specified granularity create a temporal(see the
temporal framework of grass) dataset with registered data.
Best,
Matej
On Sun, Jan 15, 2017 at 10:33 AM Micha Silver <micha at arava.co.il> wrote:
I anyone working on importing/analyzing/interpolating commercial microwave
link (CML) data in GRASS ? Is the g.gui.mwprecip addon still actively
supported?
Thanks,
Micha
-------- Forwarded Message --------
Subject: Grass
Date: Sat, 14 Jan 2017 21:56:45 +0200
From: Erick Fredj <erick.fredj at gmail.com> <erick.fredj at gmail.com>
To: Micha Silver <micha at arava.co.il> <micha at arava.co.il>
micha do you know this function in Grass
https://grass.osgeo.org/grass72/manuals/addons/g.gui.mwprecip.html
shavuha tov
Prof. Erick Fredj
Computer Science Department
The Jerusalem College of Technology
21 Havaad Haleumi St., P.O. Box 16031,
Jerusalem 91160, Israel,
Tel: +972 2 6751 287
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170117/1303928d/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170117/1303928d/attachment-0001.obj>
Type: application/pdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170117/1303928d/attachment-0001.pdf>
