[GRASS-user] g.gui.mwprecip addon
    Markus Neteler
    neteler at osgeo.org
    Wed Jan 18 02:12:20 PST 2017
Hi Matej,
On Tue, Jan 17, 2017 at 10:03 PM, Matej Krejci <matejkrejci at gmail.com> wrote:
> Hi Micha,
> development of g.gui.metada and mw.precip has been stopped. The module is
> suited for Postgres database. It basically means you need to know database
> structure. Unfortunately, I don't have rights to provide you training data.
> I have attached the sample of SQL dump which helps you to create the
> database. By modifying  COPY statements you can easily add your data.
.... could the SQL-dump be added to the addons repo?
Markus
> The computation of average precipitation along link is based on ITU-R
> P.838-3(attached). Basically, you specify a dry period for attenuation
> baseline computation and the wanted time interval you are interested in. The
> main purpose of this module was to preprocess data. It should compute
> precipitation and for specified granularity create a temporal(see the
> temporal framework of grass) dataset with registered data.
> Best,
> Matej
