[GRASS-user] Image segmentation
Giuseppe Amatulli
giuseppe.amatulli at gmail.com
Wed Jan 18 11:16:10 PST 2017
Hi all,
I would like to "segment" an image using a sort of Voronoi
<https://urldefense.proofpoint.com/v2/url?u=https-3A__en.wikipedia.org_wiki_Voronoi-5Fdiagram&d=CwMFaQ&c=-dg2m7zWuuDZ0MUcV7Sdqw&r=WXcS58IfKIlNshJRe1p51UO4aV2lTPDP2KeAvExEWkM&m=-q05ggwZ7xB31XO6ZJhmFYht4GKQ2nmFojS6li_t2As&s=Cqh6IsnZ5-oxcE2yVMRceyhb4KwTB2q3ihdDv8E4GWg&e=>
algorithm
on a cost surface instead of distance between point.
Below you can see an image where the black pixels identity areas with high
cost value. I would like to identify the "valley" between theses black
areas.
In the second image I draft by hand an ideal solution for few high cost
areas.
Which grass command can do this kind of delineation?
Thanks,
Giuseppe
[image: Inline images 1]
[image: Inline images 2]
Giuseppe Amatulli, Ph.D.
Research scientist at
Yale School of Forestry & Environmental Studies
Yale Center for Research Computing
Center for Science and Social Science Information
New Haven, 06511
Teaching: http://spatial-ecology.org
<https://urldefense.proofpoint.com/v2/url?u=http-3A__spatial-2Decology.org&d=CwMFaQ&c=-dg2m7zWuuDZ0MUcV7Sdqw&r=WXcS58IfKIlNshJRe1p51UO4aV2lTPDP2KeAvExEWkM&m=-q05ggwZ7xB31XO6ZJhmFYht4GKQ2nmFojS6li_t2As&s=2WUybjpe6r7Te9PU70VIWSGVIuSPRvgtrQM-Ej6RBuY&e=>
Work: https://environment.yale.edu/profile/giuseppe-amatulli/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170118/5f03605d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170118/5f03605d/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170118/5f03605d/attachment-0003.png>
