[GRASS-user] Image segmentation
Pedro VenĂ¢ncio
pedrongvenancio at gmail.com
Wed Jan 18 11:27:20 PST 2017
Hi Giuseppe,
Maybe you can use r.watershed [0] to get the "basins".
Best regards,
Pedro VenĂ¢ncio
[0] https://grass.osgeo.org/grass72/manuals/r.watershed.html
2017-01-18 19:16 GMT+00:00 Giuseppe Amatulli <giuseppe.amatulli at gmail.com>:
> Hi all,
> I would like to "segment" an image using a sort of Voronoi
> <https://urldefense.proofpoint.com/v2/url?u=https-3A__en.wikipedia.org_wiki_Voronoi-5Fdiagram&d=CwMFaQ&c=-dg2m7zWuuDZ0MUcV7Sdqw&r=WXcS58IfKIlNshJRe1p51UO4aV2lTPDP2KeAvExEWkM&m=-q05ggwZ7xB31XO6ZJhmFYht4GKQ2nmFojS6li_t2As&s=Cqh6IsnZ5-oxcE2yVMRceyhb4KwTB2q3ihdDv8E4GWg&e=> algorithm
> on a cost surface instead of distance between point.
> Below you can see an image where the black pixels identity areas with high
> cost value. I would like to identify the "valley" between theses black
> areas.
> In the second image I draft by hand an ideal solution for few high cost
> areas.
> Which grass command can do this kind of delineation?
> Thanks,
> Giuseppe
> [image: Inline images 1]
> [image: Inline images 2]
> Giuseppe Amatulli, Ph.D.
> Research scientist at
> Yale School of Forestry & Environmental Studies
> Yale Center for Research Computing
> Center for Science and Social Science Information
> New Haven, 06511
> Teaching: http://spatial-ecology.org
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__spatial-2Decology.org&d=CwMFaQ&c=-dg2m7zWuuDZ0MUcV7Sdqw&r=WXcS58IfKIlNshJRe1p51UO4aV2lTPDP2KeAvExEWkM&m=-q05ggwZ7xB31XO6ZJhmFYht4GKQ2nmFojS6li_t2As&s=2WUybjpe6r7Te9PU70VIWSGVIuSPRvgtrQM-Ej6RBuY&e=>
> Work: https://environment.yale.edu/profile/giuseppe-amatulli/
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170118/df4e23af/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170118/df4e23af/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170118/df4e23af/attachment-0003.png>
