[GRASS-user] Archiving GPM 3hr rainrate in GRASS
Laurent C.
lrntct at gmail.com
Fri Jan 20 16:04:51 PST 2017
Hello all,
I wrote a module that automatically download, import and register GPM
IMERG maps in GRASS.
You will need a NASA Earthdata Login to download the data. The code
can be found here:
https://bitbucket.org/lrntct/t.rast.in.gpm
For now, it is limited to IMERGHH data.
Hope it could help people working with those data.
Regards,
Laurent
2015-03-19 10:50 GMT-06:00 Laurent C. <lrntct at gmail.com>:
> Hi all,
> I'm coming back to that subject because the GPM datas are finally available
> since December 2014. The original data are stored in HDF5, which is
> supported by GDAL.
> However, I had a problem with the geo-referencing of the data. It seems that
> the lat/long coordinates are flipped.
> The problem seems to come from GDAL, as the HDF5 driver still don't support
> GPM data:
> http://www.gdal.org/frmt_hdf5.html
> I've actually downloaded a regional extracts the data in NetCDF from a NASA
> website, although I can't remember where exactly, as there are several
> services. Those data suffer from the same problem of inverted coordinates.
> So I used the ncpdq from NCO package to fix the NetCDF directly, and a tiny
> Python script to batch process the files :
> #!/usr/bin/env python
> from os import listdir
> import subprocess
> for input_file in listdir(main_path):
> output_file = input_file + '_fixed'
> subprocess.call(['ncpdq','-a', 'lat,lon', input_file, output_file])
> After batch import the data in GRASS, maintaining the original name
> including timestep, which looks like this:
> 3B-HHR.MS.MRG.3IMERG.20140619-S000000-E002959.0000.V03D
> A Python script to register the maps in temporal framework:
> import grass.script as grass
> # retrieve the list of maps
> maplist = grass.read_command('g.list', type = 'raster',
> pattern = '*IMERG*')
> # turn result in a list
> maplist = maplist.split()
> file_name = 'gpm_timestamp.txt'
> # creating the file containing the timepstamp
> list_file = open(file_name,'w')
> # iterate through the maps
> for input_map in maplist:
> # split line to keep only the timestamp
> raw_ts = input_map.split('.')[4]
> # isolate the date
> raw_mapdate = raw_ts.split('-')[0]
> # put the date in form
> mapdate = raw_mapdate[:4] + '-' + raw_mapdate[4:6] + \
> '-' + raw_mapdate[6:]
> # isolate the start time
> raw_start_time = raw_ts.split('-')[1]
> start_time = raw_start_time[1:3] + ':' + \
> raw_start_time[3:5] + ':' + raw_start_time[5:]
> # isolate the end time
> raw_end_time = raw_ts.split('-')[2]
> # put the end time in form
> end_time = raw_end_time[1:3] + ':' + \
> raw_end_time[3:5] + ':' + raw_end_time[5:]
> # put timestamp in form
> timestamp = mapdate + ' ' + start_time + '|' + mapdate + \
> ' ' + end_time
> # format the whole line
> line = input_map + '|' + timestamp + '\n'
> # write line to the file
> list_file.write(line)
> # close the file
> list_file.close()
> # register the maps in grass space_time dataset
> grass.run_command('t.register', input = 'GPM_ZMCM', file = file_name)
> Hope it will help other peoples having trouble using those data.
> Regards,
> Laurent
> 2014-11-06 5:15 GMT-06:00 maning sambale <emmanuel.sambale at gmail.com>:
>> Thanks Markus. Already registered and can access ftp. Unfortunately,
>> processed (L3) rainfall data will be released by Dec 2014.
>> Will just wait then. :)
>> On Thu, Nov 6, 2014 at 4:27 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> > On Mon, Nov 3, 2014 at 10:18 AM, maning sambale
>> > <emmanuel.sambale at gmail.com> wrote:
>> >> Has anyone here able to archive and load GPM dataset into GRASS? I
>> >> was able to get TRMM netcdf in my area of interest before, but I can't
>> >> find the tools to automate GPM downloads.
>> >> Thanks!
>> >> [0] http://www.nasa.gov/mission_pages/GPM/main/
>> > They state
>> > "All data are freely available through the NASA's Precipitation
>> > Processing System at http://pps.gsfc.nasa.gov"
>> > --> "Register and search for GPM and TRMM data, order custom subsets
>> > and set up subscriptions using PPS Data Products Ordering Interface
>> > (STORM)."
>> > At time the server seems to be down?
>> > Markus
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
