[GRASS-user] Archiving GPM 3hr rainrate in GRASS
Veronica Andreo
veroandreo at gmail.com
Sun Jan 22 04:56:56 PST 2017
Hello Laurent
w00t! This new add-on sounds very nice! I'd like to do some testing.
However, I tried to install it via g.extension and I get the following:
g.extension extension=t.rast.in.gpm url=
https://bitbucket.org/lrntct/t.rast.in.gpm
Fetching <t.rast.in.gpm> from
<https://bitbucket.org/lrntct/t.rast.in.gpm/get/default.zip> (be
patient)...
ERROR: Extension <t.rast.in.gpm> not found
Is it intended to install with g.extension?
thanks much!
Vero
2017-01-21 1:04 GMT+01:00 Laurent C. <lrntct at gmail.com>:
> Hello all,
> I wrote a module that automatically download, import and register GPM
> IMERG maps in GRASS.
> You will need a NASA Earthdata Login to download the data. The code
> can be found here:
> For now, it is limited to IMERGHH data.
> Hope it could help people working with those data.
> Regards,
> Laurent
> 2015-03-19 10:50 GMT-06:00 Laurent C. <lrntct at gmail.com>:
> > Hi all,
> > I'm coming back to that subject because the GPM datas are finally
> available
> > since December 2014. The original data are stored in HDF5, which is
> > supported by GDAL.
> > However, I had a problem with the geo-referencing of the data. It seems
> that
> > the lat/long coordinates are flipped.
> > The problem seems to come from GDAL, as the HDF5 driver still don't
> support
> > GPM data:
> > http://www.gdal.org/frmt_hdf5.html
> > I've actually downloaded a regional extracts the data in NetCDF from a
> NASA
> > website, although I can't remember where exactly, as there are several
> > services. Those data suffer from the same problem of inverted
> coordinates.
> > So I used the ncpdq from NCO package to fix the NetCDF directly, and a
> tiny
> > Python script to batch process the files :
> > #!/usr/bin/env python
> > from os import listdir
> > import subprocess
> > for input_file in listdir(main_path):
> > output_file = input_file + '_fixed'
> > subprocess.call(['ncpdq','-a', 'lat,lon', input_file, output_file])
> > After batch import the data in GRASS, maintaining the original name
> > including timestep, which looks like this:
> > 3B-HHR.MS.MRG.3IMERG.20140619-S000000-E002959.0000.V03D
> > A Python script to register the maps in temporal framework:
> > import grass.script as grass
> > # retrieve the list of maps
> > maplist = grass.read_command('g.list', type = 'raster',
> > pattern = '*IMERG*')
> > # turn result in a list
> > maplist = maplist.split()
> > file_name = 'gpm_timestamp.txt'
> > # creating the file containing the timepstamp
> > list_file = open(file_name,'w')
> > # iterate through the maps
> > for input_map in maplist:
> > # split line to keep only the timestamp
> > raw_ts = input_map.split('.')[4]
> > # isolate the date
> > raw_mapdate = raw_ts.split('-')[0]
> > # put the date in form
> > mapdate = raw_mapdate[:4] + '-' + raw_mapdate[4:6] + \
> > '-' + raw_mapdate[6:]
> > # isolate the start time
> > raw_start_time = raw_ts.split('-')[1]
> > start_time = raw_start_time[1:3] + ':' + \
> > raw_start_time[3:5] + ':' + raw_start_time[5:]
> > # isolate the end time
> > raw_end_time = raw_ts.split('-')[2]
> > # put the end time in form
> > end_time = raw_end_time[1:3] + ':' + \
> > raw_end_time[3:5] + ':' + raw_end_time[5:]
> > # put timestamp in form
> > timestamp = mapdate + ' ' + start_time + '|' + mapdate + \
> > ' ' + end_time
> > # format the whole line
> > line = input_map + '|' + timestamp + '\n'
> > # write line to the file
> > list_file.write(line)
> > # close the file
> > list_file.close()
> > # register the maps in grass space_time dataset
> > grass.run_command('t.register', input = 'GPM_ZMCM', file = file_name)
> > Hope it will help other peoples having trouble using those data.
> > Regards,
> > Laurent
> > 2014-11-06 5:15 GMT-06:00 maning sambale <emmanuel.sambale at gmail.com>:
> >> Thanks Markus. Already registered and can access ftp. Unfortunately,
> >> processed (L3) rainfall data will be released by Dec 2014.
> >> Will just wait then. :)
> >> On Thu, Nov 6, 2014 at 4:27 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >> > On Mon, Nov 3, 2014 at 10:18 AM, maning sambale
> >> > <emmanuel.sambale at gmail.com> wrote:
> >> >> Has anyone here able to archive and load GPM dataset into GRASS? I
> >> >> was able to get TRMM netcdf in my area of interest before, but I
> can't
> >> >> find the tools to automate GPM downloads.
> >> >> Thanks!
> >> >> [0] http://www.nasa.gov/mission_pages/GPM/main/
> >> > They state
> >> > "All data are freely available through the NASA's Precipitation
> >> > Processing System at http://pps.gsfc.nasa.gov"
> >> > --> "Register and search for GPM and TRMM data, order custom subsets
> >> > and set up subscriptions using PPS Data Products Ordering Interface
> >> > (STORM)."
> >> > At time the server seems to be down?
> >> > Markus
> >> cheers,
> >> maning
> >> "Freedom is still the most radical idea of all" -N.Branden
> >> wiki: http://esambale.wikispaces.com/
> >> blog: http://epsg4253.wordpress.com/
> >> _______________________________________________
> >> grass-user mailing list
> >> grass-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-user
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170122/f0a82ccc/attachment.html>
