[GRASS-user] Archiving GPM 3hr rainrate in GRASS
Laurent C.
lrntct at gmail.com
Tue Jan 24 09:39:37 PST 2017
Hello Veronica,
Thanks for your interest. I've made some change to the code,
especially added a HTML file. I think it was the reason why
g.extension was failing.
The installation works now from a local folder. For some reason it
seems that g.extension fails to download the code from bitbucket.
If you download the repository of clone it first, it should work.
I'd be glad to hear your comments.
Cheers,
Laurent
2017-01-22 6:56 GMT-06:00 Veronica Andreo <veroandreo at gmail.com>:
> Hello Laurent
> w00t! This new add-on sounds very nice! I'd like to do some testing.
> However, I tried to install it via g.extension and I get the following:
> g.extension extension=t.rast.in.gpm
> url=https://bitbucket.org/lrntct/t.rast.in.gpm
> Fetching <t.rast.in.gpm> from
> <https://bitbucket.org/lrntct/t.rast.in.gpm/get/default.zip> (be
> patient)...
> ERROR: Extension <t.rast.in.gpm> not found
> Is it intended to install with g.extension?
> thanks much!
> Vero
> 2017-01-21 1:04 GMT+01:00 Laurent C. <lrntct at gmail.com>:
>> Hello all,
>> I wrote a module that automatically download, import and register GPM
>> IMERG maps in GRASS.
>> You will need a NASA Earthdata Login to download the data. The code
>> can be found here:
>> For now, it is limited to IMERGHH data.
>> Hope it could help people working with those data.
>> Regards,
>> Laurent
>> 2015-03-19 10:50 GMT-06:00 Laurent C. <lrntct at gmail.com>:
>> > Hi all,
>> > I'm coming back to that subject because the GPM datas are finally
>> > available
>> > since December 2014. The original data are stored in HDF5, which is
>> > supported by GDAL.
>> > However, I had a problem with the geo-referencing of the data. It seems
>> > that
>> > the lat/long coordinates are flipped.
>> > The problem seems to come from GDAL, as the HDF5 driver still don't
>> > support
>> > GPM data:
>> > http://www.gdal.org/frmt_hdf5.html
>> > I've actually downloaded a regional extracts the data in NetCDF from a
>> > NASA
>> > website, although I can't remember where exactly, as there are several
>> > services. Those data suffer from the same problem of inverted
>> > coordinates.
>> > So I used the ncpdq from NCO package to fix the NetCDF directly, and a
>> > tiny
>> > Python script to batch process the files :
>> > #!/usr/bin/env python
>> > from os import listdir
>> > import subprocess
>> > for input_file in listdir(main_path):
>> > output_file = input_file + '_fixed'
>> > subprocess.call(['ncpdq','-a', 'lat,lon', input_file, output_file])
>> > After batch import the data in GRASS, maintaining the original name
>> > including timestep, which looks like this:
>> > 3B-HHR.MS.MRG.3IMERG.20140619-S000000-E002959.0000.V03D
>> > A Python script to register the maps in temporal framework:
>> > import grass.script as grass
>> > # retrieve the list of maps
>> > maplist = grass.read_command('g.list', type = 'raster',
>> > pattern = '*IMERG*')
>> > # turn result in a list
>> > maplist = maplist.split()
>> > file_name = 'gpm_timestamp.txt'
>> > # creating the file containing the timepstamp
>> > list_file = open(file_name,'w')
>> > # iterate through the maps
>> > for input_map in maplist:
>> > # split line to keep only the timestamp
>> > raw_ts = input_map.split('.')[4]
>> > # isolate the date
>> > raw_mapdate = raw_ts.split('-')[0]
>> > # put the date in form
>> > mapdate = raw_mapdate[:4] + '-' + raw_mapdate[4:6] + \
>> > '-' + raw_mapdate[6:]
>> > # isolate the start time
>> > raw_start_time = raw_ts.split('-')[1]
>> > start_time = raw_start_time[1:3] + ':' + \
>> > raw_start_time[3:5] + ':' + raw_start_time[5:]
>> > # isolate the end time
>> > raw_end_time = raw_ts.split('-')[2]
>> > # put the end time in form
>> > end_time = raw_end_time[1:3] + ':' + \
>> > raw_end_time[3:5] + ':' + raw_end_time[5:]
>> > # put timestamp in form
>> > timestamp = mapdate + ' ' + start_time + '|' + mapdate + \
>> > ' ' + end_time
>> > # format the whole line
>> > line = input_map + '|' + timestamp + '\n'
>> > # write line to the file
>> > list_file.write(line)
>> > # close the file
>> > list_file.close()
>> > # register the maps in grass space_time dataset
>> > grass.run_command('t.register', input = 'GPM_ZMCM', file = file_name)
>> > Hope it will help other peoples having trouble using those data.
>> > Regards,
>> > Laurent
>> > 2014-11-06 5:15 GMT-06:00 maning sambale <emmanuel.sambale at gmail.com>:
>> >> Thanks Markus. Already registered and can access ftp. Unfortunately,
>> >> processed (L3) rainfall data will be released by Dec 2014.
>> >> Will just wait then. :)
>> >> On Thu, Nov 6, 2014 at 4:27 PM, Markus Neteler <neteler at osgeo.org>
>> >> wrote:
>> >> > On Mon, Nov 3, 2014 at 10:18 AM, maning sambale
>> >> > <emmanuel.sambale at gmail.com> wrote:
>> >> >> Has anyone here able to archive and load GPM dataset into GRASS? I
>> >> >> was able to get TRMM netcdf in my area of interest before, but I
>> >> >> can't
>> >> >> find the tools to automate GPM downloads.
>> >> >> Thanks!
>> >> >> [0] http://www.nasa.gov/mission_pages/GPM/main/
>> >> > They state
>> >> > "All data are freely available through the NASA's Precipitation
>> >> > Processing System at http://pps.gsfc.nasa.gov"
>> >> > --> "Register and search for GPM and TRMM data, order custom subsets
>> >> > and set up subscriptions using PPS Data Products Ordering Interface
>> >> > (STORM)."
>> >> > At time the server seems to be down?
>> >> > Markus
>> >> cheers,
>> >> maning
>> >> "Freedom is still the most radical idea of all" -N.Branden
>> >> wiki: http://esambale.wikispaces.com/
>> >> blog: http://epsg4253.wordpress.com/
>> >> _______________________________________________
>> >> grass-user mailing list
>> >> grass-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-user
>> https://lists.osgeo.org/mailman/listinfo/grass-user
