[GRASS-user] Archiving GPM 3hr rainrate in GRASS
    Veronica Andreo
    veroandreo at gmail.com
    Wed Jan 25 03:48:07 PST 2017
Hello Laurent,
Ok, I was able to install the add-on by cloning the repo and then
installing from local folder:
git clone https://bitbucket.org/lrntct/t.rast.in.gpm.git
g.extension t.rast.in.gpm url=/home/veroandreo/software/t.rast.in.gpm/
I then installed nco toolbox, authorized NASA GESDISC DATA ARCHIVE and
created the .netrc file.
man t.rast.in.gpm gave me the needed help :) So I used the following and it
worked as expected...
t.rast.in.gpm start_date=2016-01-01 end_date=2016-01-02 output=prueba_imerg
However... maybe it would be useful to add an example to the manual (?).
And just a suggestion, though I'm not aware how difficult it might be: a
'-l' flag to list the available products/variables.
I like the module very much! Thanks!
Vero
2017-01-24 18:39 GMT+01:00 Laurent C. <lrntct at gmail.com>:
> Hello Veronica,
> Thanks for your interest. I've made some change to the code,
> especially added a HTML file. I think it was the reason why
> g.extension was failing.
> The installation works now from a local folder. For some reason it
> seems that g.extension fails to download the code from bitbucket.
> If you download the repository of clone it first, it should work.
> I'd be glad to hear your comments.
> Cheers,
> Laurent
> 2017-01-22 6:56 GMT-06:00 Veronica Andreo <veroandreo at gmail.com>:
> > Hello Laurent
> > w00t! This new add-on sounds very nice! I'd like to do some testing.
> > However, I tried to install it via g.extension and I get the following:
> > g.extension extension=t.rast.in.gpm
> > url=https://bitbucket.org/lrntct/t.rast.in.gpm
> > Fetching <t.rast.in.gpm> from
> > <https://bitbucket.org/lrntct/t.rast.in.gpm/get/default.zip> (be
> > patient)...
> > ERROR: Extension <t.rast.in.gpm> not found
> > Is it intended to install with g.extension?
> > thanks much!
> > Vero
> > 2017-01-21 1:04 GMT+01:00 Laurent C. <lrntct at gmail.com>:
> >> Hello all,
> >> I wrote a module that automatically download, import and register GPM
> >> IMERG maps in GRASS.
> >> You will need a NASA Earthdata Login to download the data. The code
> >> can be found here:
> >> For now, it is limited to IMERGHH data.
> >> Hope it could help people working with those data.
> >> Regards,
> >> Laurent
> >> 2015-03-19 10:50 GMT-06:00 Laurent C. <lrntct at gmail.com>:
> >> > Hi all,
> >> > I'm coming back to that subject because the GPM datas are finally
> >> > available
> >> > since December 2014. The original data are stored in HDF5, which is
> >> > supported by GDAL.
> >> > However, I had a problem with the geo-referencing of the data. It
> seems
> >> > that
> >> > the lat/long coordinates are flipped.
> >> > The problem seems to come from GDAL, as the HDF5 driver still don't
> >> > support
> >> > GPM data:
> >> > http://www.gdal.org/frmt_hdf5.html
> >> > I've actually downloaded a regional extracts the data in NetCDF from a
> >> > NASA
> >> > website, although I can't remember where exactly, as there are several
> >> > services. Those data suffer from the same problem of inverted
> >> > coordinates.
> >> > So I used the ncpdq from NCO package to fix the NetCDF directly, and a
> >> > tiny
> >> > Python script to batch process the files :
> >> > #!/usr/bin/env python
> >> > from os import listdir
> >> > import subprocess
> >> > for input_file in listdir(main_path):
> >> >     output_file = input_file + '_fixed'
> >> >     subprocess.call(['ncpdq','-a', 'lat,lon', input_file,
> output_file])
> >> > After batch import the data in GRASS, maintaining the original name
> >> > including timestep, which looks like this:
> >> > 3B-HHR.MS.MRG.3IMERG.20140619-S000000-E002959.0000.V03D
> >> > A Python script to register the maps in temporal framework:
> >> > import grass.script as grass
> >> > # retrieve the list of maps
> >> > maplist = grass.read_command('g.list', type = 'raster',
> >> >     pattern = '*IMERG*')
> >> > # turn result in a list
> >> > maplist = maplist.split()
> >> > file_name = 'gpm_timestamp.txt'
> >> > # creating the file containing the timepstamp
> >> > list_file = open(file_name,'w')
> >> > # iterate through the maps
> >> > for input_map in maplist:
> >> >     # split line to keep only the timestamp
> >> >     raw_ts = input_map.split('.')[4]
> >> >     # isolate the date
> >> >     raw_mapdate = raw_ts.split('-')[0]
> >> >     # put the date in form
> >> >     mapdate = raw_mapdate[:4] + '-' + raw_mapdate[4:6] + \
> >> >         '-' + raw_mapdate[6:]
> >> >     # isolate the start time
> >> >     raw_start_time = raw_ts.split('-')[1]
> >> >     start_time = raw_start_time[1:3] + ':' + \
> >> >         raw_start_time[3:5] + ':' + raw_start_time[5:]
> >> >     # isolate the end time
> >> >     raw_end_time = raw_ts.split('-')[2]
> >> >     # put the end time in form
> >> >     end_time = raw_end_time[1:3] + ':' + \
> >> >         raw_end_time[3:5] + ':' + raw_end_time[5:]
> >> >     # put timestamp in form
> >> >     timestamp = mapdate + ' ' + start_time + '|' + mapdate + \
> >> >         ' ' + end_time
> >> >     # format the whole line
> >> >     line = input_map + '|' + timestamp + '\n'
> >> >     # write line to the file
> >> >     list_file.write(line)
> >> > # close the file
> >> > list_file.close()
> >> > # register the maps in grass space_time dataset
> >> > grass.run_command('t.register', input = 'GPM_ZMCM', file = file_name)
> >> > Hope it will help other peoples having trouble using those data.
> >> > Regards,
> >> > Laurent
> >> > 2014-11-06 5:15 GMT-06:00 maning sambale <emmanuel.sambale at gmail.com
> >> >> Thanks Markus.  Already registered and can access ftp.
> Unfortunately,
> >> >> processed (L3) rainfall data will be released by Dec 2014.
> >> >> Will just wait then. :)
> >> >> On Thu, Nov 6, 2014 at 4:27 PM, Markus Neteler <neteler at osgeo.org>
> >> >> wrote:
> >> >> > On Mon, Nov 3, 2014 at 10:18 AM, maning sambale
> >> >> > <emmanuel.sambale at gmail.com> wrote:
> >> >> >> Has anyone here able to archive and load GPM dataset into GRASS?
> I
> >> >> >> was able to get TRMM netcdf in my area of interest before, but I
> >> >> >> can't
> >> >> >> find the tools to automate GPM downloads.
> >> >> >> Thanks!
> >> >> >> [0] http://www.nasa.gov/mission_pages/GPM/main/
> >> >> > They state
> >> >> > "All data are freely available through the NASA's Precipitation
> >> >> > Processing System at http://pps.gsfc.nasa.gov"
> >> >> > --> "Register and search for GPM and TRMM data, order custom
> subsets
> >> >> > and set up subscriptions using PPS Data Products Ordering Interface
> >> >> > (STORM)."
> >> >> > At time the server seems to be down?
> >> >> > Markus
> >> >> cheers,
> >> >> maning
> >> >> "Freedom is still the most radical idea of all" -N.Branden
> >> >> wiki: http://esambale.wikispaces.com/
> >> >> blog: http://epsg4253.wordpress.com/
> >> >> _______________________________________________
> >> >> grass-user mailing list
> >> >> grass-user at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/grass-user
> >> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170125/538af72a/attachment-0001.html>
