[GRASS-user] Error i.pansharpen landsat8 image !
Mounirsky
kaizersozy at gmail.com
Sun Jan 22 02:03:12 PST 2017
Dear users,I'm using grass.script.core to run the "i.pansharpen" command as
fallow :['i.pansharpen', '--o', 'blue=LC8_image_B2', 'green=LC8_image_B3',
'red=LC8_image_B4', 'output=pan_brovey', 'method=brovey',
'pan=LC8_image_B8']and I get this error :/Calculating Brovey
transformation...Assigning grey equalized color tables to output
images...Traceback (most recent call last): File
"/usr/lib/grass72/scripts/i.pansharpen", line 452, in main() File
"/usr/lib/grass72/scripts/i.pansharpen", line 319, in main flags="e",
color='grey') File "/usr/lib/grass72/etc/python/grass/script/core.py", line
410, in run_command return handle_errors(returncode, returncode, args,
kwargs) File "/usr/lib/grass72/etc/python/grass/script/core.py", line 329,
in handle_errors
returncode=returncode)grass.exceptions.CalledModuleError: Module None :
['r.colors', '--q', '-e', 'color=grey', 'map=pan_brovey_red'] ended with an
error/Can you please help me to get it work ?Regards,
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-i-pansharpen-landsat8-image-tp5304319.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170122/0792f6d9/attachment.html>
