[GRASS-user] Can't use v.overlay on patched vector
Jeshua Lacock
jeshua at 3DTOPO.com
Wed Jul 19 00:01:22 PDT 2017
Greetings,
I can’t seem to patch two vectors together with an attribute table then use the v.overlay command on the patched vector. I can use v.overlay if I don’t use v.patch's -e option, but I need the attribute table. Any way around this?
If I run these commands:
v.patch -e input=Road,Road2 output=RoadAll
v.overlay ainput=RoadAll binput=bounds operator=and output=RoadAll_crop
I get these warnings and error:
WARNING: Database connection not defined for layer 1
WARNING: DBMI-DBF driver: column name 'a_PERMANENT_' truncated to
'a_PERMANEN'
WARNING: DBMI-DBF driver: column name 'a_SOURCE_FEA' truncated to
'a_SOURCE_F'
WARNING: DBMI-DBF driver: column name 'a_SOURCE_DAT' truncated to
'a_SOURCE_D'
WARNING: DBMI-DBF driver: column name 'a_SOURCE_D00' truncated to
'a_SOURCE_D'
DBMI-DBF driver error:
Column 'a_SOURCE_D' already exists (duplicate name)
Unable to create table.Unable to execute statement.
ERROR: Unable to create table: 'create table RoadAll_crop (cat integer
, a_cat integer, a_TEMP varchar(200), a_TNMFRC varchar(200),
a_PERMANENT_ varchar(200), a_SOURCE_FEA varchar(200), a_SOURCE_DAT
varchar(200), a_SOURCE_D00 varchar(200), a_SOURCE_ORI varchar(200),
a_LOADDATE varchar(200), a_INTERSTATE varchar(200), a_INTERSTA00
varchar(200), a_INTERSTA01 varchar(200), a_INTERSTA02 varchar(200),
a_US_ROUTE varchar(200), a_US_ROUTE_A varchar(200), a_US_ROUTE_B
varchar(200), a_US_ROUTE_C varchar(200), a_STATE_ROUT varchar(200),
a_STATE_RO00 varchar(200), a_STATE_RO01 varchar(200), a_STATE_RO02
varchar(200), a_COUNTY_ROU varchar(200), a_FEDERAL_LA varchar(200),
a_STCO_FIPSC varchar(200), a_FULL_STREE varchar(200), a_MTFCC_CODE
varchar(200), a_SHAPE_LENG varchar(200), b_cat integer )'
Thanks,
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
