[GRASS-user] Help
Markus Neteler neteler at osgeo.org
Tue Jun 6 13:21:59 PDT 2017
Hi Patricia,
On Tue, Jun 6, 2017 at 9:16 PM, Szalona P <Patrycja2131 at onet.pl> wrote:
> Hello :D My name is Patricia and need help with GRASS. Will be visible if you
> help me find some information about the GRASS operation:D
Much is covered here:
https://grass.osgeo.org/grass72/manuals/index.html
and nice tutorials are here:
https://grass.osgeo.org/documentation/tutorials/
> So I need to know :
> 1.What is the proper sequence of the basic elements of the GRASS
> hierarchical data structure?
You can find that here in a graphical view:
https://svn.osgeo.org/grass/grass/trunk/doc/grass_database.png
and more detailed here:
https://grass.osgeo.org/grass72/manuals/helptext.html#2.-background:-grass-gis-location-structure
> 2.Does g.region have mandatory parameters? If yes, then specify what ?
In general no, it can run with a single flag like "-p" for print the
current region.
See
https://grass.osgeo.org/grass72/manuals/g.region.html
> 3.To open multiple graphical monitors, command line mode allows the GRASS
> system ?
You can use
d.mon wx0
see
https://grass.osgeo.org/grass72/manuals/d.mon.html
> 4.What is the full (obligatory) syntax of a command that allows you to
> display basic GRASS layer information?
d.rast rastermap
d.vect vectormap
> 5.How do you know the parameters of a region assigned to a raster layer
> called powiats? Enter a command or command to let you know.
g.region raster=powiats -p
> 6.The command syntax along with the appropriate parameter to display the
> vector layers available in the system?
g.list vector
> 7.Command name and its mandatory parameters to display a composite image
> composed of three RGB color channels. Layer names can be fictitious
d.rgb ... :-)
> 8After changing the working area (computational), this information should be
> passed to the graphical command line mode window. Give commands that you can
> use
d.erase
> 9.To test how many pixels in the raster layer have a given average value,
> use the command
> Along with the parameters (flags):
There are different possibilities, eg with r.mapcalc or r.stats or others.
> 10.
> Write the command syntax along with the formula (raster map calculator),
> which will give you a new raster floating point class, called alpha, as a
> result of the formula calculation:
> alfa=(2⋅sin(srednia"\_"beta))/3
Similar to what you wrote but be sure to have white space left and
right from the " = " sign.
> 11
> Write a command syntax that will allow you to calculate the TVI vegetative
> index. The input layers are landsat_band3 and landsat_band4.
> TVI=√((NDVI+0.5) )
Check i.vi and r.mapcalc.
> I  really needs help because nobody at all does not want to give me any
> information:/
HTH,
Markus
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
