[GRASS-user] i.superpixels.slic not working
James Duffy
james.philip.duffy at gmail.com
Mon Jun 12 02:38:48 PDT 2017
On 12 June 2017 at 10:36, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 12/06/17 11:25, James Duffy wrote:
>> Hello,
>> I'm trying to run the following:
>> *i.superpixels.slic -n group=mod1 at PERMANENT output=test num_pixels=5000
>> memory=10000
>> The output gives me the following:
>> (Mon Jun 12 10:17:40
>> 2017)
>> memory=10000
>> Cache data in memory mode
>> Loading input...
>> WARNING: Initialized 5036 of 5070 seeds
>> Performing k mean segmentation...
>> And then I get a 'GRASS 7 has stopped working' box pop up.
>> I tried again with the default settings for the module:
>> *i.superpixels.slic group=mod1 at PERMANENT output=test
>> And got the same error.
>> I am using windows 10 professional and GRASS 7.3.svn (2017).
>> Has anyone else got this module working, or had the same problem on
>> Windows?
> I haven't had any problems running it on Linux, and some colleagues have
> run it on Windows.
> Just for our info: What are your region settings ?
projection: 1 (UTM)
zone: 43
datum: wgs84
ellipsoid: wgs84
north: 25183.22184529
south: 25157.71783908
west: 301463.66480893
east: 301494.2431551
nsres: 0.07775612
ewres: 0.0778075
rows: 328
cols: 393
cells: 128904
Just to add, I am running i.segment.uspo without problems using the same
imagery group and the same region.
> Moritz
*James Duffy*
PhD Researcher
Environment and Sustainability Institute
Penryn Campus
University of Exeter
Penryn
Cornwall
TR10 9FE
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170612/0e798329/attachment.html>
