[GRASS-user] i.superpixels.slic not working
Moritz Lennert mlennert at club.worldonline.be
Mon Jun 12 02:36:59 PDT 2017
On 12/06/17 11:25, James Duffy wrote:
> Hello,
> I'm trying to run the following:
> *i.superpixels.slic -n group=mod1 at PERMANENT output=test num_pixels=5000
> memory=10000
> The output gives me the following:
> (Mon Jun 12 10:17:40
> 2017)
> memory=10000
> Cache data in memory mode
> Loading input...
> WARNING: Initialized 5036 of 5070 seeds
> Performing k mean segmentation...
> And then I get a 'GRASS 7 has stopped working' box pop up.
> I tried again with the default settings for the module:
> *i.superpixels.slic group=mod1 at PERMANENT output=test
> And got the same error.
> I am using windows 10 professional and GRASS 7.3.svn (2017).
> Has anyone else got this module working, or had the same problem on Windows?
I haven't had any problems running it on Linux, and some colleagues have
run it on Windows.
Just for our info: What are your region settings ?
Moritz
