[GRASS-user] Matching Histograms for Aerial Photography?
Jeshua Lacock
jeshua at 3DTOPO.com
Tue Jun 20 23:03:17 PDT 2017
> On Jun 20, 2017, at 6:02 AM, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> You can try the addon: i.histo.match. You can install it with g.extension.
Hi Moritz,
Thanks for the suggestion. Currently the data is raster - I assume I will have to convert it to imagery?
I tried installing the extension, but it fails with an SSL certificate error. I don’t see anyway to ignore or use a non-secure transfer.
Here is the output:
GRASS 7.2.1 (naipWest):~ > g.extension extension=i.histo.match
Fetching <i.histo.match> from GRASS GIS Addons repository (be patient)...
File "/opt/local/share/grass-7.2.1/scripts/g.extension", line 1733, in <module>
sys.exit(main())
File "/opt/local/share/grass-7.2.1/scripts/g.extension", line 1712, in main
install_extension(source=source, url=url, xmlurl=xmlurl)
File "/opt/local/share/grass-7.2.1/scripts/g.extension", line 683, in install_extension
source=source, url=url)
File "/opt/local/share/grass-7.2.1/scripts/g.extension", line 1146, in install_extension_std_platforms
outdev=outdev, directory=srcdir, tmpdir=TMPDIR)
File "/opt/local/share/grass-7.2.1/scripts/g.extension", line 1094, in download_source_code
f, h = urlretrieve(url, zip_name)
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib.py", line 98, in urlretrieve
return opener.retrieve(url, filename, reporthook, data)
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib.py", line 245, in retrieve
fp = self.open(url, data)
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib.py", line 213, in open
return getattr(self, name)(url)
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib.py", line 443, in open_https
h.endheaders(data)
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1038, in endheaders
self._send_output(message_body)
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 882, in _send_output
self.send(msg)
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 844, in send
self.connect()
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1263, in connect
server_hostname=server_hostname)
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 363, in wrap_socket
_context=self)
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 611, in __init__
self.do_handshake()
File "/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 840, in do_handshake
self._sslobj.do_handshake()
IOError: [Errno socket error] [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)
Best,
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
