[GRASS-user] Projection errors with Aster GDEM and SHP Files
preiaen
nils.hempel at gmx.de
Wed Jun 28 07:02:58 PDT 2017
Dear Markus,
thank you for your answer. I did as you suggested and below are the results.
As far as I can understand it, it looks fine, however the error remains.
*For the shapefile: *
*g.proj -g:*
-PROJ_INFO-------------------------------------------------
name : WGS 84 / Pseudo-Mercator
datum : wgs84
ellps : wgs84
proj : merc
lat_ts : 0.0
lon_0 : 0.0
x_0 : 0.0
y_0 : 0
k : 1.0
wktext : defined
no_defs : defined
-PROJ_EPSG-------------------------------------------------
epsg : 3857
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
*ogrinfo:*
PROJCS["WGS 84 / Pseudo-Mercator",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]],
PROJECTION["Mercator_1SP"],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["X",EAST],
AXIS["Y",NORTH],
EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
+lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext
+no_defs"],
AUTHORITY["EPSG","3857"]]
*For the DEM:*
g.proj -p
datum : wgs84
ellps : wgs84
proj : ll
no_defs : defined
unit : degree
units : degrees
meters : 1.0
*gdalinfo:*
GEOGCS["WGS 84",
DATUM["WGS_1984",
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
Nils
View this message in context: http://osgeo-org.1560.x6.nabble.com/Projection-errors-with-Aster-GDEM-and-SHP-Files-tp5324655p5325865.html
Sent from the Grass - Users mailing list archive at Nabble.com.
