[GRASS-user] r.water.outlet map does not display
Laurent C.
lrntct at gmail.com
Mon Mar 6 15:19:30 PST 2017
Hello,
You should make sure that the point you give to r.water.outlet is
located on a main stream. The accumulation map from r.watershed is
useful for this task.
If you're not doing so, you might end up with a tiny watershed.
Regards,
Laurent
2017-03-06 16:50 GMT-06:00 Rich Shepard <rshepard at appl-ecosys.com>:
> Using r.watershed specifying the input DEM and a name for the drainage map
> I can view the drainage map. When I follow this command with r.water.outlet
> specifying the drainage map as input, 'watershed' as the output map name,
> and the coordinates of the designated outlet, no map is displayable.
> Could this be due to the very flat nature of the terrain?
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
