[GRASS-user] r.water.outlet map does not display
Rich Shepard
rshepard at appl-ecosys.com
Mon Mar 6 15:27:51 PST 2017
On Mon, 6 Mar 2017, Laurent C. wrote:
> You should make sure that the point you give to r.water.outlet is located
> on a main stream. The accumulation map from r.watershed is useful for this
> task. If you're not doing so, you might end up with a tiny watershed.
Laurent,
There are no streams in this area, only a couple of ditches.
Rich
