[GRASS-user] Itzi output: several questions
Rich Shepard
rshepard at appl-ecosys.com
Tue Mar 14 15:01:06 PDT 2017
On Mon, 13 Mar 2017, Laurent C. wrote:
> The water level of 3m seems to be due to accumulation on the edge of the
> domain. The water flows according to topography. If there is a lower point
> without an exit, there will be an accumulation of water. If you want a map
> in cm or mm, you can convert it using r.mapcalc.
Laurent,
If I copy the strds can I run r.mapcalc on all the maps in it to convert
from meters to centimeters? Have not before worked with s-t data sets so I'm
unfamiliar with applying r.mapcalc collectively to a set of raster maps.
Rich
