[GRASS-user] Itzi output: several questions
Laurent C. lrntct at gmail.com
Tue Mar 14 15:37:53 PDT 2017
2017-03-14 16:01 GMT-06:00 Rich Shepard <rshepard at appl-ecosys.com>:
> On Mon, 13 Mar 2017, Laurent C. wrote:
>> The water level of 3m seems to be due to accumulation on the edge of the
>> domain. The water flows according to topography. If there is a lower point
>> without an exit, there will be an accumulation of water. If you want a map
>> in cm or mm, you can convert it using r.mapcalc.
> Laurent,
>   If I copy the strds can I run r.mapcalc on all the maps in it to convert
> from meters to centimeters? Have not before worked with s-t data sets so I'm
> unfamiliar with applying r.mapcalc collectively to a set of raster maps.
You might try t.rast.mapcalc.
Laurent
