[GRASS-user] GRASS, ordinal not in range(128)
Andres Solarte e.andres.solartec at gmail.com
Wed Mar 15 04:59:48 PDT 2017
Hello Vero
Thank you for your answer, I'm glad to be here too!
I followed your steps and I have the same problem :(
GRASS 7.3.svn (prueba):~ > for i in `seq 1 5` ; do r.mapcalc
"prueba_andres${i} = 3" ; done
 100%
 100%
 100%
 100%
 100%
GRASS 7.3.svn (prueba):~ > t.create type=strds temporaltype=absolute
output=ndvi_andres title="NDVI prueba" description="prueba tesis"
semantictype=mean
GRASS 7.3.svn (prueba):~ >  t.register -i type=raster input=ndvi_andres
maps=`g.list raster pattern=prueba_andres* separator=comma`
start="2015-09-07" increment="1 days"
Reuniendo información del mapa...
ERROR: ascii,Definir tiempo absoluto válido para mapa <,25,26,ordinal not
       in range(128)
The dataset is available in the link below. The images were resampled but I
think that's not the problem :S
https://drive.google.com/open?id=0B5vy4w_s2kxmNXhnY0doYzQtN0E
Once again, thanks for your answer
Regards,
Andrés.
2017-03-15 4:49 GMT-03:00 Veronica Andreo <veroandreo at gmail.com>:
> Hola Andres!
> Bienvenido a la lista! I'm glad that you write here :)
> I regularly use t.register with MODIS products, and haven't found that
> ERROR you describe. Moreover, I did some testing, just creating ad-hoc
> maps, creating the strds and then registering those maps and all went fine.
> I cannot reproduce the error that you get.
> Here are my steps:
>  for i in `seq 1 5` ; do r.mapcalc "prueba_andres${i} = 3" ; done
>  100%
>  100%
>  100%
>  100%
>  100%
> GRASS 7.3.svn (latlong_wgs84):~ > t.create type=strds
> temporaltype=absolute output=ndvi_andres title="NDVI prueba"
> description="prueba tesis" semantictype=mean
> GRASS 7.3.svn (latlong_wgs84):~ > t.register -i type=raster
> input=ndvi_andres maps=`g.list raster pattern=prueba_andres*
> separator=comma` start="2015-09-07" increment="1 days"
> Gathering map information...
>  100%
> Registering maps in the temporal database...
> Registering maps in the space time dataset...
> Updating space time dataset...
>  100%
> all fine...
> Is there anything special with those maps you use, i.e: which processing
> have they gone through?
> Maybe you could put them in a dropbox and share so someone else can access
> them and test
> Cheers,
> Vero
> 2017-03-12 12:01 GMT+01:00 Andres Solarte <e.andres.solartec at gmail.com>:
>> Hello Markus
>> I'm working on Ubuntu 14.04 and the path is /home/andres/Escritorio/prueba
>> s
>> Regards
>> 2017-03-12 7:08 GMT-03:00 Markus Neteler <neteler at osgeo.org>:
>>> On Sat, Mar 11, 2017 at 9:49 PM, Andres Solarte
>>> <e.andres.solartec at gmail.com> wrote:
>>> > Hello, I'm trying to work with temporal series using GRASS GIS, but
>>> when I
>>> > try to register maps an error occurs:
>>> not
>>> >        in range(128)
>>> Just wondering:
>>> - which operating system do you use?
>>> - given your name "Andrés" - do you have special characters in the path?
>>> Best
>>> Markus
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170315/65528165/attachment.html>
