[GRASS-user] GRASS, ordinal not in range(128)
Veronica Andreo veroandreo at gmail.com
Fri Mar 17 01:59:09 PDT 2017
Hola Andres,
I just tested with your data...
No issues here. As you say, it must be something else... but I have no
hint... I'm sorry
Hope someone else can point you to a solution
un beso,
Vero
2017-03-15 12:59 GMT+01:00 Andres Solarte <e.andres.solartec at gmail.com>:
> Hello Vero
> Thank you for your answer, I'm glad to be here too!
> I followed your steps and I have the same problem :(
> GRASS 7.3.svn (prueba):~ > for i in `seq 1 5` ; do r.mapcalc
> "prueba_andres${i} = 3" ; done
>  100%
>  100%
>  100%
>  100%
>  100%
> GRASS 7.3.svn (prueba):~ > t.create type=strds temporaltype=absolute
> output=ndvi_andres title="NDVI prueba" description="prueba tesis"
> semantictype=mean
> GRASS 7.3.svn (prueba):~ >  t.register -i type=raster input=ndvi_andres
> maps=`g.list raster pattern=prueba_andres* separator=comma`
> start="2015-09-07" increment="1 days"
> Reuniendo información del mapa...
> ERROR: ascii,Definir tiempo absoluto válido para mapa <,25,26,ordinal not
>        in range(128)
> The dataset is available in the link below. The images were resampled but
> I think that's not the problem :S
> https://drive.google.com/open?id=0B5vy4w_s2kxmNXhnY0doYzQtN0E
> Once again, thanks for your answer
> Regards,
> Andrés.
> 2017-03-15 4:49 GMT-03:00 Veronica Andreo <veroandreo at gmail.com>:
>> Hola Andres!
>> Bienvenido a la lista! I'm glad that you write here :)
>> I regularly use t.register with MODIS products, and haven't found that
>> ERROR you describe. Moreover, I did some testing, just creating ad-hoc
>> maps, creating the strds and then registering those maps and all went fine.
>> I cannot reproduce the error that you get.
>> Here are my steps:
>>  for i in `seq 1 5` ; do r.mapcalc "prueba_andres${i} = 3" ; done
>>  100%
>>  100%
>>  100%
>>  100%
>>  100%
>> GRASS 7.3.svn (latlong_wgs84):~ > t.create type=strds
>> temporaltype=absolute output=ndvi_andres title="NDVI prueba"
>> description="prueba tesis" semantictype=mean
>> GRASS 7.3.svn (latlong_wgs84):~ > t.register -i type=raster
>> input=ndvi_andres maps=`g.list raster pattern=prueba_andres*
>> separator=comma` start="2015-09-07" increment="1 days"
>> Gathering map information...
>>  100%
>> Registering maps in the temporal database...
>> Registering maps in the space time dataset...
>> Updating space time dataset...
>>  100%
>> all fine...
>> Is there anything special with those maps you use, i.e: which processing
>> have they gone through?
>> Maybe you could put them in a dropbox and share so someone else can
>> access them and test
>> Cheers,
>> Vero
>> 2017-03-12 12:01 GMT+01:00 Andres Solarte <e.andres.solartec at gmail.com>:
>>> Hello Markus
>>> I'm working on Ubuntu 14.04 and the path is
>>> /home/andres/Escritorio/pruebas
>>> Regards
>>> 2017-03-12 7:08 GMT-03:00 Markus Neteler <neteler at osgeo.org>:
>>>> On Sat, Mar 11, 2017 at 9:49 PM, Andres Solarte
>>>> <e.andres.solartec at gmail.com> wrote:
>>>> > Hello, I'm trying to work with temporal series using GRASS GIS, but
>>>> when I
>>>> > try to register maps an error occurs:
>>>> not
>>>> >        in range(128)
>>>> Just wondering:
>>>> - which operating system do you use?
>>>> - given your name "Andrés" - do you have special characters in the path?
>>>> Best
>>>> Markus
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170317/51b48fab/attachment.html>
