[GRASS-user] [ERROR 4:unable to open EPSG support file gcs.csv]
Ang Sherpa
angsherpa232 at gmail.com
Sun Mar 19 22:50:21 PDT 2017
Hi users,
I am trying to produce basin shape-file and then save in desktop in new
directory with python script. Interestingly, it gets welly executed in my
PC as expected. However, with the same script following error is thrown in
my laptop.
r.to.vect complete
ERROR 4:Unable to open EPSG support file gcs.csv.
Try setting the GDAL_DATA environment variable to point to the directory
containing EPSG csv files.
ERROR: Unknown EPSG code 32645
The projection system that I am working is:
name: WGS 84 / UTM zone 45N
datum: wgs84
ellps: wgs84
proj: utm
zone: 45
My laptop processor is AMD 64-bit processor and PC is i7 series 64 bit
processor. The grass 7.2.0 on both system.
Any solution will be much appreciated.
*Best,*
*Ang Dawa Sherpa*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170320/f9e333a8/attachment.html>
