[GRASS-user] [ERROR 4:unable to open EPSG support file gcs.csv]
Helmut Kudrnovsky
hellik at web.de
Sun Mar 19 23:22:47 PDT 2017
Ang Sherpa wrote
> Hi users,
> I am trying to produce basin shape-file and then save in desktop in new
> directory with python script. Interestingly, it gets welly executed in my
> PC as expected. However, with the same script following error is thrown in
> my laptop.
> r.to.vect complete
> ERROR 4:Unable to open EPSG support file gcs.csv.
> Try setting the GDAL_DATA environment variable to point to the directory
> containing EPSG csv files.
> ERROR: Unknown EPSG code 32645
> The projection system that I am working is:
> name: WGS 84 / UTM zone 45N
> datum: wgs84
> ellps: wgs84
> proj: utm
> zone: 45
> My laptop processor is AMD 64-bit processor and PC is i7 series 64 bit
> processor. The grass 7.2.0 on both system.
> Any solution will be much appreciated.
> *Best,*
> *Ang Dawa Sherpa*
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user
This may be an issue of your GDAL installation.
Which OS are you using? Linux? Windows? Mac?
Running gdal-config --datadir shows where GDAL searches for gcs.csv.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp5313117p5313118.html
Sent from the Grass - Users mailing list archive at Nabble.com.
