[GRASS-user] [ERROR 4:unable to open EPSG support file gcs.csv]
Helmut Kudrnovsky
hellik at web.de
Mon Mar 20 02:54:46 PDT 2017
[please keep it on the mailing list! others can help and others can benefit from the answers!]
> I am using windows 10 * 64-bit processor in my PC and windows 8 * 64 bit processor in my laptop.
>Running gdal-config --datadir throws error:
>'gdal-config' is not recognized as an internal or external command,
>operable program or batch file.
OK; in winGRASS, there is no gdal-config, thus the error.
which winGRASS are you using? standalone-winGRASS 7.2.0? OSGeo4W-winGRASS 7.2.0?
testing it here with:
System Info
GRASS version: 7.2.0
GRASS SVN revision: r70156
Build date: 2016-12-29
Build platform: i386-w64-mingw32
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
typing in the winGRASS-windows console:
C:\>echo %GDAL_DATA%
C:\OSGeo4W\share\gdal
here the %GDAL_DATA% variable points to the correct path.
try the same on both your working and not working system and report the differences.
kind regards
Helmut
Gesendet: Montag, 20. März 2017 um 08:31 Uhr
Betreff: Re: [GRASS-user] [ERROR 4:unable to open EPSG support file gcs.csv]
Thanks,
Best,
On Mon, Mar 20, 2017 at 12:07 PM, Helmut Kudrnovsky <hellik at web.de[mailto:hellik at web.de]> wrote:Ang Sherpa wrote
> Hi users,
> I am trying to produce basin shape-file and then save in desktop in new
> directory with python script. Interestingly, it gets welly executed in my
> PC as expected. However, with the same script following error is thrown in
> my laptop.
> r.to.vect complete
> ERROR 4:Unable to open EPSG support file gcs.csv.
> Try setting the GDAL_DATA environment variable to point to the directory
> containing EPSG csv files.
> ERROR: Unknown EPSG code 32645
> The projection system that I am working is:
> name: WGS 84 / UTM zone 45N
> datum: wgs84
> ellps: wgs84
> proj: utm
> zone: 45
> My laptop processor is AMD 64-bit processor and PC is i7 series 64 bit
> processor. The grass 7.2.0 on both system.
> Any solution will be much appreciated.
> *Best,*
> *Ang Dawa Sherpa*
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user[https://lists.osgeo.org/mailman/listinfo/grass-user]
This may be an issue of your GDAL installation.
Which OS are you using? Linux? Windows? Mac?
Running gdal-config --datadir shows where GDAL searches for gcs.csv.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp5313117p5313118.html[http://osgeo-org.1560.x6.nabble.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp5313117p5313118.html]
Sent from the Grass - Users mailing list archive at Nabble.com.
grass-user at lists.osgeo.org[mailto:grass-user at lists.osgeo.org]
