[GRASS-user] GRASS, ordinal not in range(128)
Moritz Lennert mlennert at club.worldonline.be
Tue Mar 21 01:22:20 PDT 2017
Le 21 mars 2017 04:38:11 GMT+01:00, Andres Solarte <e.andres.solartec at gmail.com> a écrit :
>Ok, but I changed the language on ubuntu. It solved the problem.
Yes. Could you change it back to what it was and then run the command in debug mode as suggested by Markus ?
Moritz
>Enviado desde mi smartphone BlackBerry 10.
>  Mensaje original
>De: Markus Neteler
>Enviado: lunes, 20 de marzo de 2017 23:24
>Para: Moritz Lennert
>CC: grass-user at lists.osgeo.org
>Asunto: Re: [GRASS-user] GRASS, ordinal not in range(128)
>On Mon, Mar 20, 2017 at 11:12 AM, Moritz Lennert
><mlennert at club.worldonline.be> wrote:
>> [Please keep discussions on the list]
>> Le Sun, 19 Mar 2017 19:27:28 -0300,
>> Luiz Andrade <lcoandrade at gmail.com> a écrit :
>>> Well, normally this is a problem when GRASS finds special characters
>>> (e.g. á, é, à, ã, etc). Check your strings for those characters and
>>> remove them.
>> The problem here does not seem to be with file or path names as
>> everything works when the locale is set to en_US.
>> So there seems to be an issue when a different locale is used. This
>is
>> not something the user can handle, but is in the code.
>It would really help if you could change the debug level with
>g.gisenv set=DEBUG=1 # or 2 or 3 ...
>and then run
>t.register ...
>to see in the output where the problem roughly happens.
>To switch back to "debug silence", run then:
>g.gisenv set=DEBUG=0
>Markus
>_______________________________________________
>grass-user mailing list
>https://lists.osgeo.org/mailman/listinfo/grass-user
