[GRASS-user] STRDS animation: failed to render
Rich Shepard rshepard at appl-ecosys.com
Wed Mar 22 14:54:38 PDT 2017
On Wed, 22 Mar 2017, Sören Gebbert wrote:
> unfortunately renaming of raster layers with g.rename is not recognized by
> the temporal framework. You have to remove the old strds and register the
> renamed maps in a new strds. Using t.rast.list on the old strds will give
> you a map list that you can use as template for registering.
Soeren,
   Thank you. Will do.
Rich
