[GRASS-user] t.register syntax
Sören Gebbert
soerengebbert at googlemail.com
Wed Mar 22 16:25:36 PDT 2017
Use the comma separator option for g.list since a comma separated list
of maps is required for the maps option in t.register.
2017-03-23 0:16 GMT+01:00 Rich Shepard <rshepard at appl-ecosys.com>:
> I thought I had recorded the syntax for creating strds's from existing
> raster maps, but I neglected to do so. (t.create worked correctly and the
> strds exists.)
> This command fails:
> t.register -i input=blocked_h maps=`g.list type=raster pattern=blocked_h_*`
> type=raster separator=comma start="2013-11-15" increment="1 days"
> with a series of error messages like this:
> ERROR: Sorry <blocked_h_0002> is not a valid option
> The maps to be registered are:
> blocked_h_0001
> blocked_h_0002
> blocked_h_0003
> blocked_h_0004
> blocked_h_0005
> blocked_h_0006
> blocked_h_0007
> blocked_h_0008
> blocked_h_0009
> blocked_h_0010
> blocked_h_0011
> blocked_h_0012
> blocked_h_0013
> blocked_h_0014
> blocked_h_0015
> blocked_h_0016
> blocked_h_0017
> blocked_h_0018
> blocked_h_0019
> blocked_h_0020
> blocked_h_0021
> blocked_h_0022
> blocked_h_0023
> blocked_h_max
> I'm not seeing the parameter that I've not entered or the one that should
> be entered. Please correct my syntax and this time I'll be certain to write
> it down!
> TIA,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
