[GRASS-user] [ERROR 4:unable to open EPSG support file gcs.csv]
Ang Sherpa angsherpa232 at gmail.com
Sat Mar 25 00:26:58 PDT 2017
Hi users,
When I tried adding C:\Program Files\GRASS GIS 7.2.0\share\gdal to the
system path with following line of code, it doesnot work as expected. Am I
missing something?
My code is
new_path = r'C:\Program Files\GRASS GIS 7.2.0\share\gdal'
os.environ['PATH'] += os.pathsep + new_path
Still this error persist.
ERROR 4:Unable to open EPSG support file gcs.csv.
Try setting the GDAL_DATA environment variable to point to the directory
containing EPSG csv files.
ERROR: Unknown EPSG code 32645
*Best,*
*Ang Dawa Sherpa*
On Tue, Mar 21, 2017 at 3:36 PM, Ang Sherpa <angsherpa232 at gmail.com> wrote:
> Yes, gcs.csv exists in both machine. Well, I reinstalled Grass 7.2 and it
> worked.
> Thanks.
> *Regards,*
> *Ang Dawa Sherpa*
> *GIS technician - Irrigation Master Plan*
> *WRPPF - DOI, Nepal Government*
> *Lalitpur*
> *contact: 984 007 3861*
> On Tue, Mar 21, 2017 at 3:23 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
>> Ang Sherpa wrote
>> > Thanks Helmut,
>> > I am using standalone-winGRASS 7.2.0
>> > In both my PC and laptop when: echo %GDAL_DATA% is executed in
>> > winGRASS-console it shows the same location:
>> > c:\Program Files\GRASS GIS 7.2.0\Share\gdal
>> could you have a look if gcs.csv lives in the folder above?
>> may you re-install your winGRASS standalone-winGRASS 7.2.0?
>> may you try OSGeo4W-winGRASS 7.2.0 (https://trac.osgeo.org/osgeo4w/)?
>> can't reproduce the error here at the moment.
>> best regards
>> Helmut
>> View this message in context: http://osgeo-org.1560.x6.nabbl
>> e.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp531
>> 3117p5313354.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170325/fee5ce0d/attachment.html>
