[GRASS-user] [ERROR 4:unable to open EPSG support file gcs.csv]
Helmut Kudrnovsky hellik at web.de
Sat Mar 25 03:17:05 PDT 2017
Ang Sherpa wrote
> Hi users,
> When I tried adding C:\Program Files\GRASS GIS 7.2.0\share\gdal to the
> system path with following line of code, it doesnot work as expected. Am I
> missing something?
> My code is
> new_path = r'C:\Program Files\GRASS GIS 7.2.0\share\gdal'
> os.environ['PATH'] += os.pathsep + new_path
> Still this error persist.
> ERROR 4:Unable to open EPSG support file gcs.csv.
> Try setting the GDAL_DATA environment variable to point to the directory
> containing EPSG csv files.
> ERROR: Unknown EPSG code 32645
> *Best,*
> *Ang Dawa Sherpa*
> On Tue, Mar 21, 2017 at 3:36 PM, Ang Sherpa <
> angsherpa232@
> > wrote:
>> Yes, gcs.csv exists in both machine. Well, I reinstalled Grass 7.2 and it
>> worked.
>> Thanks.
>> *Regards,*
>> *Ang Dawa Sherpa*
>> *GIS technician - Irrigation Master Plan*
>> *WRPPF - DOI, Nepal Government*
>> *Lalitpur*
>> *contact: 984 007 3861*
>> On Tue, Mar 21, 2017 at 3:23 PM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>>> Ang Sherpa wrote
>>> > Thanks Helmut,
>>> > I am using standalone-winGRASS 7.2.0
>>> > In both my PC and laptop when: echo %GDAL_DATA% is executed in
>>> > winGRASS-console it shows the same location:
>>> > c:\Program Files\GRASS GIS 7.2.0\Share\gdal
>>> could you have a look if gcs.csv lives in the folder above?
>>> may you re-install your winGRASS standalone-winGRASS 7.2.0?
>>> may you try OSGeo4W-winGRASS 7.2.0 (https://trac.osgeo.org/osgeo4w/)?
>>> can't reproduce the error here at the moment.
>>> best regards
>>> Helmut
>>> View this message in context: http://osgeo-org.1560.x6.nabbl
>>> e.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp531
>>> 3117p5313354.html
>>> Sent from the Grass - Users mailing list archive at Nabble.com.
>>> grass-user mailing list
> grass-user at .osgeo
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
AFAIK adding the gdal related folder to %PATH% doesn't help.
As mentioned in the error message, the variable %GDAL_DATA%
should be defined in your script.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp5313117p5314199.html
