[GRASS-user] [ERROR 4:unable to open EPSG support file gcs.csv]
Ang Sherpa
angsherpa232 at gmail.com
Sat Mar 25 03:24:07 PDT 2017
Thanks for attention,
Tried everything I could. Any solution to incorporate %GDAL_DATA% in the
script, other than to manually adding GDAL_DATA path in system variable?
*Best,*
*Ang Dawa Sherpa*
On Sat, Mar 25, 2017 at 4:02 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Ang Sherpa wrote
> > Hi users,
> > When I tried adding C:\Program Files\GRASS GIS 7.2.0\share\gdal to the
> > system path with following line of code, it doesnot work as expected. Am
> I
> > missing something?
> > My code is
> > new_path = r'C:\Program Files\GRASS GIS 7.2.0\share\gdal'
> > os.environ['PATH'] += os.pathsep + new_path
> > Still this error persist.
> > ERROR 4:Unable to open EPSG support file gcs.csv.
> > Try setting the GDAL_DATA environment variable to point to the directory
> > containing EPSG csv files.
> > ERROR: Unknown EPSG code 32645
> > *Best,*
> > *Ang Dawa Sherpa*
> > On Tue, Mar 21, 2017 at 3:36 PM, Ang Sherpa <
> > angsherpa232@
> > > wrote:
> >> Yes, gcs.csv exists in both machine. Well, I reinstalled Grass 7.2 and
> it
> >> worked.
> >> Thanks.
> >> *Regards,*
> >> *Ang Dawa Sherpa*
> >> *GIS technician - Irrigation Master Plan*
> >> *WRPPF - DOI, Nepal Government*
> >> *Lalitpur*
> >> *contact: 984 007 3861*
> >> On Tue, Mar 21, 2017 at 3:23 PM, Helmut Kudrnovsky <
> > hellik@
> > > wrote:
> >>> Ang Sherpa wrote
> >>> > Thanks Helmut,
> >>> > I am using standalone-winGRASS 7.2.0
> >>> > In both my PC and laptop when: echo %GDAL_DATA% is executed in
> >>> > winGRASS-console it shows the same location:
> >>> > c:\Program Files\GRASS GIS 7.2.0\Share\gdal
> >>> could you have a look if gcs.csv lives in the folder above?
> >>> may you re-install your winGRASS standalone-winGRASS 7.2.0?
> >>> may you try OSGeo4W-winGRASS 7.2.0 (https://trac.osgeo.org/osgeo4w/)?
> >>> can't reproduce the error here at the moment.
> >>> best regards
> >>> Helmut
> >>> View this message in context: http://osgeo-org.1560.x6.nabbl
> >>> e.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-csv-tp531
> >>> 3117p5313354.html
> >>> Sent from the Grass - Users mailing list archive at Nabble.com.
> >>> _______________________________________________
> >>> grass-user mailing list
> > grass-user at .osgeo
> >>> https://lists.osgeo.org/mailman/listinfo/grass-user
> AFAIK adding the gdal related folder to %PATH% doesn't help.
> As mentioned in the error message, the variable %GDAL_DATA%
> should be defined in your script.
> best regards
> Helmut
> nabble.com/ERROR-4-unable-to-open-EPSG-support-file-gcs-
> csv-tp5313117p5314199.html
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170325/2fdc858a/attachment.html>
