[GRASS-user] [snap pour point for r.water.outlet]
Ang Sherpa angsherpa232 at gmail.com
Wed Mar 29 23:21:44 PDT 2017
Thanks Johannes,
r.stream.snap does not have attribute table attached and throws an error:
"DB connection for vector map XXX not defined."
With this case, it won't be of any good use as coordinate of new snaped
point cannot be extracted for feeding into "r.water.outlet" - coordinate
field.
*Best,*
*Ang Dawa Sherpa*
*Regards,*
*Ang Dawa Sherpa*
*GIS technician - Irrigation Master Plan*
*WRPPF - DOI, Nepal Government*
*Lalitpur*
*contact: 984 007 3861*
On Thu, Mar 30, 2017 at 11:58 AM, Johannes Radinger <
johannesradinger at gmail.com> wrote:
> Sorry I ment r.stream.snap...
> -------- Original message --------
> From: Ang Sherpa
> Date:30/03/2017 07:32 (GMT+01:00)
> To: Johannes Radinger
> Cc: Helmut Kudrnovsky , GRASS user list
> Subject: Re: [GRASS-user] [snap pour point for r.water.outlet]
> Thanks Johannes,
> Installed. No I have not installed r.stream.order, is it mandatory or ease
> the process?
> *Best,*
> *Ang Dawa Sherpa*
> On Thu, Mar 30, 2017 at 10:23 AM, Johannes Radinger <
>> Dear Ang Sherpa,
>> r.stream.snap is an add-on. So you first need to install it using e.g
>> g.extension. Have you installed r.stream.order before calling it?
>> /j
>> From: Ang Sherpa
>> Date:30/03/2017 05:34 (GMT+01:00)
>> To: Helmut Kudrnovsky , GRASS user list
>> Thanks for the link Helmut,
>> However, it throws an error stating:
>> (Thu Mar 30 09:14:55 2017)
>> r.stream.snap
>> 'r.stream.snap' is not recognized as an internal or external
>> command,
>> operable program or batch file.
>> I am using  standalone version Grass gis 7.2.0
>> *Regards,*
>> *Ang Dawa Sherpa*
>> *Lalitpur*
>> On Thu, Mar 30, 2017 at 1:03 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
>>> Ang Sherpa wrote
>>> > Hi users,
>>> > While using "r.water.outlet" to delineate watershed basin, although the
>>> > coordinates of the stream was noted from google earth and fed into
>>> > "r.water.outlet" module, it produces plain raster.
>>> > Is there any solution to make sure that the coordinates of outlet point
>>> > automatically snaps to the nearest line of stream in drainage direction
>>> > map?
>>> what about?:
>>> https://grass.osgeo.org/grass72/manuals/addons/r.stream.snap.html
>>> r.stream.snap - Snap point to modelled stream network.
>>> Input can be stream network, point vector map with outlets or outlet
>>> coordinates.
>>> best regards
>>> Helmut
>>> View this message in context: http://osgeo-org.1560.x6.nabbl
>>> e.com/snap-pour-point-for-r-water-outlet-tp5314835p5314856.html
>>> Sent from the Grass - Users mailing list archive at Nabble.com.
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170330/35d2dc08/attachment-0001.html>
