[GRASS-user] Problems with r.surf.contour
Bianca Federici bianca.federici at unige.it
Thu Mar 30 01:37:01 PDT 2017
Dear Markus,
thank you very much for your suggestion... I never used the option -a in
g.region command!
The results improved a lot, but some problems are still present in the
linear interpolation between two contour levels.
Here you may see the slope map and a slope profile that enhance the not
proper result:
https://www.dropbox.com/s/7olimii9s0m21rh/slope_contourlevel.PNG?dl=0
I hope that you or somebody else have other suggestions ;-)
     Bianca
Il 27/03/2017 21:21, Markus Metz ha scritto:
> g.region is a very powerful tool with sometimes unexpected effects.
> See suggested workflow below.
> On Mon, Mar 27, 2017 at 12:26 PM, Bianca Federici
> <bianca.federici at unige.it <mailto:bianca.federici at unige.it>> wrote:
> > Dear all,
> > I'm writing to report a problem I noticed using r.surf.contour.
> > I created a DTM from contour lines, but I notice something a wrong
> behaviour of the r.surf.contour resulting map.
> > In detail I imported with v.in.ogr a shape file describing contour
> lines every 25m of altitude
> > Then, I converted in raster (setting a resolution of the
> computational region equal to 1m), and created the DTM ( setting a
> resolution of the computational region equal to 5m) with r.surf.contour.
> > Either plotting a profile of the DTM and creating the slope map
> (with r.slope.aspect), it's evident that r.surf.contour works bad.
> > Here you can see the slope map, with the contour level in black, and
> the position of the extracted cross section; you may notice artificial
> steps mainly in corrispondence of the contour levels, instead of
> uniform slopes:
> > Here you can see the DTM profile along the cross section, that shows
> the irregular morphology of the created DTM
> > https://www.dropbox.com/s/useoxstmceyulk6/DTM_cross_section.PNG?dl=0
> > I tested it in GRASS 6.4.4, 7.0.3 and 7.2.0, working either in
> Windows and in Linux.
> > I hope that the developers team could correct this malfunction.
> > Best regards,
> >     Bianca
> > PS: The used commands:
> > v.in.ogr ...
> > g.region -p res=1
> > v.to.rast input=contourlevel25m type=line output=contourlevel25m
> use=attr column=ELEVATION
> > g.region -p res=5
> > r.surf.contour input=contourlevel25m output=dtm_contourlevel25m
> > r.slope.aspect elevation=dtm_contourlevel25m slope=slope_contourlevel25m
> Please try
> v.in.ogr ...
> g.region -p -a res=5 vect=contourlevel25m
> v.to.rast ...
> # do not change the region again
> r.surf.contour ...
> HTH,
> Markus M
> > Eng. Bianca Federici, PhD
> > Assistant Professor in Geomatics
> > DICCA - Department of Civil, Chemical and Environmental Engineering
> > Laboratory of Geodesy, Geomatics and GIS
> > University of Genoa
> > Via Montallegro, 1 - 16145 Genova ITALY
> > Phone: +39 010 353 2421 - Fax: +39 010 353 2546
> > E-mail:bianca.federici at unige.it
> <mailto:E-mail%3Abianca.federici at unige.it>
>  -www.dicca.unige.it/geomatica/ricerca
> <http://www.dicca.unige.it/geomatica/ricerca>
> > Gter srl Innovation in Geomatics, Gnss and Gis
> > Spin-off of the University of Genoa
> > Piazza De Marini 3/61, 16123 Genova
> > Phone: +39 010 8694830 - Fax: +39 010 8694737 -
> > E-mail:info at gter.it <mailto:E-mail%3Ainfo at gter.it>  -www.gter.it
> <http://www.gter.it>
> > www.facebook.com/Gteronline <http://www.facebook.com/Gteronline>
> > www.twitter.com/Gteronline <http://www.twitter.com/Gteronline>
> > Please consider the environment before printing this email!
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170330/c3a9afc3/attachment.html>
