[GRASS-user] Problems with r.surf.contour
roy roy
royroge at outlook.com
Thu Mar 30 03:33:11 PDT 2017
> thank you very much for your suggestion... I never used the option -a
> in g.region command!
> The results improved a lot, but some problems are still present in the
> linear interpolation between two contour levels.
> Here you may see the slope map and a slope profile that enhance the
> not proper result:
> https://www.dropbox.com/s/7olimii9s0m21rh/slope_contourlevel.PNG?dl=0
> I hope that you or somebody else have other suggestions ;-)
> Bianca
Hi Bianca, could you please better elaborate the problem?
Thanks.
