[GRASS-user] r.to.vect stats
Vaclav Petras wenzeslaus at gmail.com
Mon May 1 10:47:58 PDT 2017
On Mon, May 1, 2017 at 11:43 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
>> I have separated the binning code in r.in.lidar [3] so that it can be
>> used in r.in.xyz
> Is it different from the binning code in r.in.xyz ?
Not really. r.in.lidar was based on r.in.xyz, now they are different but of
course the idea is to make them again as similar as possible.
>> and the missing module which would do
>> the binning of a vector map into a raster map. There is actually a large
>> overlap with code for grid-based decimation of a point cloud (2D with
>> gridded or averaged X and Y). I already committed the code to r.in.lidar
>> [4], but we had a discussion on mailing list and decided that this
>> functionality should not be part of r.in.lidar, so it is disabled [5]
>> but the code is still there.
> So what you are saying is that the code should go into a library and be
used by all relevant modules ?
Yes. That would be ideal. Now it is in separate files in r.in.lidar and it
can be copied and synced, but I think the library would not be less general
than other libraries, so there is probably no reason to not include it. The
only reason I didn't do it is that I wanted to do the refactoring in
r.in.xyz first (which I never finished) and then work on the library.
>> Anyway, a new module needs to be implemented for this. The name can be
>> something like r.binning, r.vect.stats, r.point.stats, or
>> r.points.stats. It might good project for beginners.
> I like the idea. But do you really think this would be much faster than
v.out.ascii | r.in.xyz ?
I don't know if much faster, but it will be at least little faster. Another
issue is that "v.out.ascii | r.in.xyz" is little hard to do on MS Windows
and from GUI in general. Yes, there should have been a wrapper module for
this already, but the a module to do the task directly is seems to me as a
better solution esp. if there is the library. But the wrapper module may be
a good way to start and to decide about the name and interface.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170501/560d26d7/attachment-0001.html>
