[GRASS-user] Aggregation of massive number of raster layers with r.series
Pierre Roudier
pierre.roudier at gmail.com
Fri May 12 01:35:04 PDT 2017
Thanks Moritz,
Indeed, I ended up creating mapsets on the fly using grass72 -c, and
processing tiles in their respective mapsets.
On 12 May 2017 at 18:18, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> Le 11 mai 2017 23:30:28 GMT+02:00, Pierre Roudier <
> pierre.roudier at gmail.com> a écrit :
> >Thanks all,
> >I ended up having a script that tiles my overall region (using
> >v.mkgrid). I
> >then loop through the tiles, and create a set of subregions on the fly
> >(using the save= option available for g.region). So in the end I have
> >tiles
> >represeneted as a set of regions, named "region_[1-n]".
> >I then use the WIND_OVERRIDE env variable to process the tiles:
> >- On my personal machine, I can use GNU parallel:
> >g.list type=region pat=region_* | parallel WIND_OVERRIDE={} r.series
> >in=`g.list rast pat=temp_* sep=","` out=tiled_{} method=quantile
> >quantile=0.95 --o
> >- BUT: on the cluster, I can't use GNU parallel, so I generate one
> >script
> >per region, which essentially is a one liner:
> >WIND_OVERRIDE=region_n r.series in=`g.list rast pat=temp_* sep=","`
> >out=tiled_region_n method=quantile quantile=0.95 --o
> >This script is launch silently using GRASS_BATCH_JOB.
> >My problem now is that I got errors because several GRASS scripts are
> >hitting the GRASS database at the same time:
> >Starting GRASS GIS...
> >ERROR: pierre.roudier is currently running GRASS in selected mapset
> >(file
> >*/projects/nesi00165/nobackup/modis/grassdata/
> modis_ts/PERMANENT/PERMANENT/*.gislock
> >found). Concurrent use not allowed.
> >You can force launching GRASS using -f flag (note that you need
> >permission for this operation). Have another look in the processor
> >manager just to be sure...
> >Exiting...
> >My question: in this instance, is it safe to use the -f flag, given
> >these
> >different GRASS instances are not writing the same dataset to the DB?
> I would say that the generally recommended way would be to create separate
> mapsets to avoid such conflicts. At the end you can loop over all mapsets
> to copy the results into one final mapset.
> Moritz
> >On 21 April 2017 at 20:44, Blumentrath, Stefan
> ><Stefan.Blumentrath at nina.no>
> >wrote:
> >> Hi Pierre,
> >> tiling should speed up significantly, if you process the tiles in
> >parallel
> >> (and if you have multiple cores and if IO is not the bottleneck (e.g.
> >slow
> >> network connection to the data)).
> >> Care has to be taken with the region settings, though.
> >> See e.g.:
> >https://grasswiki.osgeo.org/wiki/Parallel_GRASS_jobs#Working_with_tiles
> >> Cheers
> >> Stefan
> >> ________________________________________
> >> Von: grass-user <grass-user-bounces at lists.osgeo.org> im Auftrag von
> >> Pierre Roudier <pierre.roudier at gmail.com>
> >> Gesendet: Freitag, 21. April 2017 00:49
> >> An: grass-user
> >> Betreff: [GRASS-user] Aggregation of massive number of raster layers
> >with
> >> r.series
> >> Hi,
> >> I am trying to compute the 95th percentile of a massive grid (12+
> >> million pixels) for a massive number of layers (~2500 layers).
> >> I am doing the aggregation using r.series on our cluster running
> >grass
> >> 7.2, but of course it takes ages (21% there after 3 days).
> >> - I tried to tile the process, but it doesn't seem to help much.
> >> - Is there any benefit for me to switch to t.rast.aggregate? My
> >> understanding was that it was a wrapper around r.series.
> >> - Does anyone have a fancy trick to make the aggregation go faster
> >> (parallelisation)?
> >> Cheers,
> >> Pierre
> >> _______________________________________________
> >> grass-user mailing list
> >> grass-user at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170512/1eb8941e/attachment.html>
