[GRASS-user] Column names of sqlite attribute tables while using v.import
Moritz Lennert mlennert at club.worldonline.be
Tue May 16 14:50:49 PDT 2017
Le 16 mai 2017 22:16:03 GMT+02:00, Johannes Radinger <johannesradinger at gmail.com> a écrit :
>Hi all,
>I tried to import a polygon shape, specifically the HydroBASINS from
>hydrosheds.org however I got following error:
>v.import
>input=/.../Hydrosheds/hybas_na_lev00_v1c/hybas_na_lev00_v1c.shp
>layer=hybas_na_lev00_v1c output=hybas_na_lev00_v1c
>WARNING: All available OGR layers will be imported into vector map
><hybas_na_lev00_v1c>
>Check if OGR layer <hybas_na_lev00_v1c> contains polygons...
>DBMI-SQLite driver error:
>Error in sqlite3_prepare():
>near "ORDER": syntax error
>ERROR: Unable to create table: 'create table hybas_na_lev00_v1c (cat
>integer, HYBAS_ID double precision, NEXT_DOWN double precision,
>NEXT_SINK
>double precision, MAIN_BAS double precision, DIST_SINK double
>precision,
>DIST_MAIN double precision, SUB_AREA double precision, UP_AREA double
>precision, ENDO integer, COAST integer, ORDER integer, SORT double
>precision, PFAF_1 integer, PFAF_2 integer, PFAF_3 integer, PFAF_4
>integer,
>PFAF_5 integer, PFAF_6 integer, PFAF_7 integer, PFAF_8 integer, PFAF_9
>integer, PFAF_10 double precision, PFAF_11 double precision, PFAF_12
>double
>precision)'
>ERROR: Unable to import
></.../Hydrosheds/hybas_na_lev00_v1c/hybas_na_lev00_v1c.shp>
>So I guess ORDER is a sqlite specific word that is reserved for SQL
>operations and is not allowed as column name? Is this a general thing
>of
>sqlite or is this just related to v.import/v.in.ogr and the creation of
>the
>sqlite table?
AFAIK, ORDER is a general SQL reserved keyword, not only in Sqlite. See [1] for example.
Moritz
[1] http://www.sql.org/sql-database/postgresql/manual/sql-keywords-appendix.html
