[GRASS-user] Column names of sqlite attribute tables while using v.import
Johannes Radinger johannesradinger at gmail.com
Wed May 17 01:02:18 PDT 2017
Thank you Moritz,
that's what I thought. So I'll try the 'columns' option in v.in.ogr to
rename the columns during import.
/johannes
On Tue, May 16, 2017 at 11:50 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> Le 16 mai 2017 22:16:03 GMT+02:00, Johannes Radinger <
> johannesradinger at gmail.com> a écrit :
> >Hi all,
> >I tried to import a polygon shape, specifically the HydroBASINS from
> >hydrosheds.org however I got following error:
> >v.import
> >input=/.../Hydrosheds/hybas_na_lev00_v1c/hybas_na_lev00_v1c.shp
> >layer=hybas_na_lev00_v1c output=hybas_na_lev00_v1c
> >WARNING: All available OGR layers will be imported into vector map
> ><hybas_na_lev00_v1c>
> >Check if OGR layer <hybas_na_lev00_v1c> contains polygons...
> >DBMI-SQLite driver error:
> >Error in sqlite3_prepare():
> >near "ORDER": syntax error
> >ERROR: Unable to create table: 'create table hybas_na_lev00_v1c (cat
> >integer, HYBAS_ID double precision, NEXT_DOWN double precision,
> >NEXT_SINK
> >double precision, MAIN_BAS double precision, DIST_SINK double
> >precision,
> >DIST_MAIN double precision, SUB_AREA double precision, UP_AREA double
> >precision, ENDO integer, COAST integer, ORDER integer, SORT double
> >precision, PFAF_1 integer, PFAF_2 integer, PFAF_3 integer, PFAF_4
> >integer,
> >PFAF_5 integer, PFAF_6 integer, PFAF_7 integer, PFAF_8 integer, PFAF_9
> >integer, PFAF_10 double precision, PFAF_11 double precision, PFAF_12
> >double
> >precision)'
> >ERROR: Unable to import
> ></.../Hydrosheds/hybas_na_lev00_v1c/hybas_na_lev00_v1c.shp>
> >So I guess ORDER is a sqlite specific word that is reserved for SQL
> >operations and is not allowed as column name? Is this a general thing
> >of
> >sqlite or is this just related to v.import/v.in.ogr and the creation of
> >the
> >sqlite table?
> AFAIK, ORDER is a general SQL reserved keyword, not only in Sqlite. See
> [1] for example.
> Moritz
> [1] http://www.sql.org/sql-database/postgresql/manual/
> sql-keywords-appendix.html
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170517/af3bce54/attachment.html>
