[GRASS-user] v.to.db area calculations
James Duffy
james.philip.duffy at gmail.com
Thu May 18 07:22:48 PDT 2017
Hello,
I'm trying to calculate the area of a polygon using v.to.db as follows
(through R):
*execGRASS("v.to.db", flags = c("p","quiet"), parameters = list(map =
"test", units = "meters", option = "area", separator = "comma"),intern =
TRUE)*
I assume that the output of this command will be a meters squared
calculation of the area inside the polygon 'test'.
However, in QGIS, I manually calculated the area the they do not match.
QGIS (which I believe to be true) shows 0.128m2, and the output from
v.to.db shows 22.42226m2.
I am working in WGS84.
Can anyone shed some light on how v.to.db calculates area and why it might
be going wrong please?
Thank you
James
*James Duffy*
PhD Researcher
Environment and Sustainability Institute
Penryn Campus
University of Exeter
Penryn
Cornwall
TR10 9FE
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170518/76f9d370/attachment.html>
