[GRASS-user] v.to.db area calculations
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Thu May 18 09:41:48 PDT 2017
Hi James,
QGIS uses a ellipsoidal area measurement, while GRASS (like most of the other GIS) uses a Cartesian measurement (others, please correct me if that is not the case in WGS84).
See amongst others:
https://issues.qgis.org/issues/12057 and
https://issues.qgis.org/issues/14675
Would you mind comparing area measurement of a third software (SAGA, PostGIS, ...)?
Cheers
Stefan
________________________________________
Von: grass-user [grass-user-bounces at lists.osgeo.org] im Auftrag von James Duffy [james.philip.duffy at gmail.com]
Gesendet: Donnerstag, 18. Mai 2017 16:22
An: grass-user
Betreff: [GRASS-user] v.to.db area calculations
Hello,
I'm trying to calculate the area of a polygon using v.to.db as follows (through R):
execGRASS("v.to.db", flags = c("p","quiet"), parameters = list(map = "test", units = "meters", option = "area", separator = "comma"),intern = TRUE)
I assume that the output of this command will be a meters squared calculation of the area inside the polygon 'test'.
However, in QGIS, I manually calculated the area the they do not match. QGIS (which I believe to be true) shows 0.128m2, and the output from v.to.db shows 22.42226m2.
I am working in WGS84.
Can anyone shed some light on how v.to.db calculates area and why it might be going wrong please?
Thank you
James
James Duffy
PhD Researcher
Environment and Sustainability Institute
Penryn Campus
University of Exeter
Penryn
Cornwall
TR10 9FE
