[GRASS-user] v.to.db area calculations
James Duffy
james.philip.duffy at gmail.com
Fri May 19 01:41:29 PDT 2017
Output from ogrinfo:
INFO: Open of `C:\Sandbox\RGRASS\DATA\training_single.shp'
using driver `ESRI Shapefile' successful.
Layer name: training_single
Metadata:
DBF_DATE_LAST_UPDATE=2017-05-17
Geometry: Polygon
Feature Count: 1
Extent: (73.213474, 0.225604) - (73.213477, 0.225608)
Layer SRS WKT:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]]
On 19 May 2017 at 09:38, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> Le 19 mai 2017 10:19:06 GMT+02:00, "Blumentrath, Stefan" <
> Stefan.Blumentrath at nina.no> a écrit :
> >Just checked the data you send offline in QGIS 2.18.0.
> >With your sample data
> >SAGA (through processing) returns an area of 0.0000…
> >QGIS with OTF ON: 34,815 m²
> >QGIS with OTF OFF: 0,127 m²
> In what projection is the original data ?
> Moritz
> >Cheers,
> >Stefan
*James Duffy*
PhD Researcher
Environment and Sustainability Institute
Penryn Campus
University of Exeter
Penryn
Cornwall
TR10 9FE
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170519/1d186206/attachment-0001.html>
