[GRASS-user] v.to.db area calculations
Moritz Lennert mlennert at club.worldonline.be
Fri May 19 01:53:40 PDT 2017
Le 19 mai 2017 10:41:29 GMT+02:00, James Duffy <james.philip.duffy at gmail.com> a écrit :
>Output from ogrinfo:
>INFO: Open of `C:\Sandbox\RGRASS\DATA\training_single.shp'
>      using driver `ESRI Shapefile' successful.
>Layer name: training_single
>Metadata:
>  DBF_DATE_LAST_UPDATE=2017-05-17
>Geometry: Polygon
>Feature Count: 1
>Extent: (73.213474, 0.225604) - (73.213477, 0.225608)
>Layer SRS WKT:
>GEOGCS["WGS 84",
>    DATUM["WGS_1984",
>        SPHEROID["WGS 84",6378137,298.257223563,
>            AUTHORITY["EPSG","7030"]],
>        AUTHORITY["EPSG","6326"]],
>    PRIMEM["Greenwich",0,
>        AUTHORITY["EPSG","8901"]],
>    UNIT["degree",0.0174532925199433,
>        AUTHORITY["EPSG","9122"]],
>    AUTHORITY["EPSG","4326"]]
Ok, so the data is in degrees and 0.127 is not in m2, but in degree2 which is not a really useful unit as its meaning on the ground depends on the latitude.
Moritz
>On 19 May 2017 at 09:38, Moritz Lennert <mlennert at club.worldonline.be>
>wrote:
>> Le 19 mai 2017 10:19:06 GMT+02:00, "Blumentrath, Stefan" <
>> Stefan.Blumentrath at nina.no> a écrit :
>> >Just checked the data you send offline in QGIS 2.18.0.
>> >With your sample data
>> >SAGA (through processing) returns an area of 0.0000…
>> >QGIS with OTF ON: 34,815 m²
>> >QGIS with OTF OFF: 0,127 m²
>> In what projection is the original data ?
>> Moritz
>> >Cheers,
>> >Stefan
