[GRASS-user] v.to.db area calculations
Markus Metz markus.metz.giswork at gmail.com
Fri May 19 02:12:30 PDT 2017
On Thu, May 18, 2017 at 4:22 PM, James Duffy <james.philip.duffy at gmail.com>
wrote:
> Hello,
> I'm trying to calculate the area of a polygon using v.to.db as follows
(through R):
> execGRASS("v.to.db", flags = c("p","quiet"), parameters = list(map =
"test", units = "meters", option = "area", separator = "comma"),intern =
TRUE)
> I assume that the output of this command will be a meters squared
calculation of the area inside the polygon 'test'.
> However, in QGIS, I manually calculated the area the they do not match.
QGIS (which I believe to be true) shows 0.128m2, and the output from
v.to.db shows 22.42226m2.
This is a large difference. Is it possible that several polygons share the
same category? In this case the entry in the attribute table is the sum of
all polygons with that category.
> I am working in WGS84.
GRASS uses geodesic distance and area calculation for latlon, I believe
QGIS as well.
Markus M
> Can anyone shed some light on how v.to.db calculates area and why it
might be going wrong please?
> Thank you
> James
> James Duffy
> PhD Researcher
> Environment and Sustainability Institute
> Penryn Campus
> University of Exeter
> Penryn
> Cornwall
> TR10 9FE
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170519/c3cef1ef/attachment.html>
