[GRASS-user] v.to.db area calculations
James Duffy james.philip.duffy at gmail.com
Wed May 24 02:06:05 PDT 2017
Hello,
Thank you for your investigations.
Is there anything else I can do about this? I trust my QGIS measurement
because I know the size of the object I have drawn around. However I would
really like to use GRASS to automate my workflow...
Thanks
James
On 19 May 2017 at 13:41, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 19/05/17 11:25, James Duffy wrote:
>> Just to clear a few things up.
>> The shapefile contains only a single polygon (I created it as a simple
>> test to work out this discrepancy).
>> OTF is turned off in QGIS, I am working in EPSG 4326.
>> The 0.127m2 comes from using the Measure tool (OTF off) in QGIS. And it
>> is set to display m2.
>> Using the $area calculator in the field calculator in QGIS does indeed
>> show something that is more likely degrees squared.
> Below some results from quick tests.
> Summary: personally I would trust GRASS GIS a bit more, but I'm biaised...
> Test 1:
> GRASS trunk in NC demo location (EPSG 3358)
> g.region n=200100 s=200000 w=500000 e=500100 -ap
> v.in.region out=nc_testpolygon
> v.to.db -p nc_testpolygon op=area --q
> 1|10000
> GRASS trunk in EPSG 4326 location
> v.proj location=nc_spm_08 mapset=user1 input=nc_testpolygon
> 1|10002.503642603
> v.out.ogr nc_testpolygon out=nc_testpolygon.shp (i.e. shapefile is in
> degress, EPSG 4326)
> QGIS (using the exported shapefile)
> No OTF
> measuring tool: 12.324,737 m²
> $area in calculator: 12320.2346026
> OTF to EPSG 4326, with datum WGS84
> measuring tool: 10.072,355 m²
> $area in calculator: 10046.3679510
> Test 2:
> GRASS trunk, in ESPG 4326 location
> g.region n=74 s=73 w=0 e=1 res=1 -p
> v.in.region region_1degree_73_74N
> v.to.db -p region_1degree_73_74N op=area --q
> 1|3539348689.40454
> v.out.ogr region_1degree_73_74N out=region_1degree_73_74N.shp
> GRASS trunk in EPSG 3575 location
> v.proj location=LL_WGS84 mapset=mlennert input=region_1degree_73_74N
> 1|3539337483.97153
> no OTF projection
> measuring tool 1,002 m² (sic)
> export geometry column: 1
> $area in calculator 12392029030.5000000
> with OTF projection, datum for measurements WGS84
> measuring tool 3.503.322.774,337 m²
> $area in calculator: 3499702798.3400998
> reproject to EPSG 3575
> with OTF, datum WGS84
> export geometry column 3539169026.18628
> export geoemtry column (column named otf) 3499702798.00000
> $area in calculator: 3499702798.6579294
*James Duffy*
PhD Researcher
Environment and Sustainability Institute
Penryn Campus
University of Exeter
Penryn
Cornwall
TR10 9FE
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170524/7515ce9d/attachment.html>
